Accuracy problems after upgrading from R16.6 to R17
  • Stormrider
    • Feb 2019
    • 8
    Hi
    aufter upgrading to R17 my accuracy for rips dropped from 95% or more to mostly less than 30% of the tracks i rip being ripped accuratly.
    Anyone experiencing similar problems?
    here's an example:
    here's the log of this rip maybe that helps to get ahold of the problem:
    The problem accurs on 2 dries built into the same computer and like i said til i updated the software worked flawless.
    Re: Accuracy problems after upgrading from R16.6 to R17
    Which DSP effects are you using?
    • Stormrider
      • Feb 2019
      • 8
      Playlist writer, HDCD and ReplayGain on both formats (i am ripping to FLAC and MP3 at the same time).
        We have been able to reproduce, for now until R17.1, set the option 'Temporary Folder' in dBpoweramp Control Center >> Advanced
        set to the same location as if you type:
        %tmp% into the path of Windows file explorer, browse to that exact path and set.
        • Stormrider
          • Feb 2019
          • 8
          Thanks for the fast reply.
          I did set the temporary folder to the standart folder windows/temp and that seems to work properly.
          Problem solve i guess.
