How Skip Over A Rejected Disc and Continue a Batch Rip
  • Bellwoods
    • Mar 2018
    Hello
    I am using Batch Ripper with a Sony VGP XL1B. I am ripping in batches of 200.
    When the system encounters a disc for which meta-data cannot be found (or there is some other defect) the batch rip process stops and waits for a manual reject disc input.
    Is there any way to configure Batch Ripper to automatically skip over a rejected disc and continue on to the next one?
    Thanks in advance.
    • 43978
    Re: How Skip Over A Rejected Disc and Continue a Batch Rip
    You can set batch ripper to rip the disc if there is no metadata, it is on the metadata options page.
    • Bellwoods
      • Mar 2018
      Thanks I am not finding that setting on Metadata Options. Is it possible I am using an obsolete versin of batch ripper?
      ALSO I may not want to rip a disc that is not tagged with metdata; is it possible to set it so any disc in the batch gets skipped if rip is not successful after X seconds?
        • 43978
        Batch Ripper Configuration 'Reject CD if no metadata' have this unchecked. And in main program, the 'force manual input and review' all off and to never
        • Bellwoods
          • Mar 2018
          I do not find any of these options in my install.
          I am using ver 16.6 - are the controls you mention only present in the latest ver (i.e. ver17)?
            • 43978
            Batch Ripper configuration is the program you used to configure the drive as a media changer.
            The other options are in Batch Ripper, not CD Ripper (R17 is CD ripper).
