Results 1 to 12 of 12
Thread: Problem Bit Depth / Dither
  1. #1
    Join Date
    Mar 2015
    Hello,
    I have one strange problem using TuneFusion: When using the "Bit Depth" DSP option "Dither" is greyed out, is it a bug? I would like to automatically convert 24Bit files from my master HDD to 16Bit with TDPF ones on the target HDD.
    Thanks for any help & Cheers,
    Oliver
  2. #2
    Join Date
    Mar 2015
    Re: Problem Bit Depth / Dither
    P.S.: Itīs the TuneFusion Prime Fully Registed version, additionally to the dbPoweramp Reference and PerfectTunes registered versions I am also using.
  3. #3
    Join Date
    Apr 2002
    Will mark it as a big to look at.
  4. #4
    Join Date
    Mar 2015
    Thank you very much, looking forward to hearing more about your findings!
  5. #5
    Join Date
    Mar 2015
    Hi Spoon,
    I was wondering if you found some time to look further into this, was the error reproducable to you? OS is Windows 10 (latest version) BTW.
    Given the current COVID19 situation I hope youīre well & safe,
    Cheers from Germany,
    Oliver
  6. #6
    Join Date
    Apr 2002
    Hi Oliver,
    Yes the issue persists, if you have dBpoweramp Reference installed copy the dll 'Bit Depth' from the dBpoweramp DSP install folder to the TuneFUSION install folder (DSP also overwriting the existing).
  7. #7
    Join Date
    Mar 2015
    Thanks for your feedback, I did as you suggested: I copied the "Bit Depth".dll of my registered dBPoweramp Reference to the TuneFusion DSP-folder. Unfortunately the problem persists, the "Dither" option is still greyed out? I am not sure if itīs of importance, prior to the registered version of TuneFusion I had the trial version installed?
  8. #8
    Join Date
    Apr 2002
    In dBpoweramp the Bit Depth does not have dither greyed out?
  9. #9
    Join Date
    Mar 2015
    Correct, in dBPoweramp thereīs three options to choose from: None, Triangular, Rectangular.
  10. #10
    Join Date
    Mar 2015
    If I may ask again, is there any chance for a solution to the problem? Cheers, Oliver
  11. #11
    Join Date
    Apr 2002
    Hopefully will get on these next week to release a new beta.
  12. #12
    Join Date
    Apr 2002
    You are using TuneFUSION?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
