Problem Bit Depth / Dither
  • -ol-
    • Mar 2015
    • 12
    Hello,
    I have one strange problem using TuneFusion: When using the "Bit Depth" DSP option "Dither" is greyed out, is it a bug? I would like to automatically convert 24Bit files from my master HDD to 16Bit with TDPF ones on the target HDD.
    Thanks for any help & Cheers,
    Oliver
  • -ol-
    • Mar 2015
    • 12
    Re: Problem Bit Depth / Dither
    P.S.: It´s the TuneFusion Prime Fully Registed version, additionally to the dbPoweramp Reference and PerfectTunes registered versions I am also using.
      • 46178
      Will mark it as a big to look at.
      • -ol-
        • Mar 2015
        • 12
        Thank you very much, looking forward to hearing more about your findings!
        • -ol-
          • Mar 2015
          • 12
          Hi Spoon,
          I was wondering if you found some time to look further into this, was the error reproducable to you? OS is Windows 10 (latest version) BTW.
          Given the current COVID19 situation I hope you´re well & safe,
          Cheers from Germany,
          Oliver
            • 46178
            Hi Oliver,
            Yes the issue persists, if you have dBpoweramp Reference installed copy the dll 'Bit Depth' from the dBpoweramp DSP install folder to the TuneFUSION install folder (DSP also overwriting the existing).
            • -ol-
              • Mar 2015
              • 12
              Thanks for your feedback, I did as you suggested: I copied the "Bit Depth".dll of my registered dBPoweramp Reference to the TuneFusion DSP-folder. Unfortunately the problem persists, the "Dither" option is still greyed out? I am not sure if it´s of importance, prior to the registered version of TuneFusion I had the trial version installed?
                • 46178
                In dBpoweramp the Bit Depth does not have dither greyed out?
                • -ol-
                  • Mar 2015
                  • 12
                  Correct, in dBPoweramp there´s three options to choose from: None, Triangular, Rectangular.
                  • -ol-
                    • Mar 2015
                    • 12
                    If I may ask again, is there any chance for a solution to the problem? Cheers, Oliver
                      • 46178
                      Hopefully will get on these next week to release a new beta.
                        • 46178
                        You are using TuneFUSION?
