High resolution audio to cd quality
  • Jackpump
    • Aug 2019
    do you lose audio quality converting 24bit 96khz music to 16bit 44khz?
    • 1846
    Re: High resolution audio to cd quality
    Yes, too obviously.
      • 45129
      You should use the DSPs in this order:
      Resample (to 44KHz)
      Set Bit Depth (to 16 bit, dithered)
      This preserves as much quality as possible in 16 bit
      • Walk7
        • Aug 2019
        44-48khz should be the limit btw any music in 96khz or 192khz just sound awful!
          • 1846
          But only if the source has been recorded with that sample rate and bit depth, or if the analogue source has been digitized in such a way. Audio CDs (Red Book Standard) are limitied to 16bit and 44,1kHz (only exeptions are the rare HDCD).
          Upsampling will never increase the quality of a signal. Downsampling will reduce the quality of a signal in most cases.
          • timster67
            • May 2014
            • 210
            I agree that 24 bit over 16 is the biggest SQ improvement, but that's not to say the sample rate isn't. I don't know where this is coming from?
              What on earth are you talking about?
              • Michael Sargent
                • Dec 2009
                • 135
                Yes, you lose audio quality.
                No, you probably won't be able to hear the difference (44/16 was chosen wisely).
                • Walk7
                  • Aug 2019
                  If y'all like 96khz and 192khz good for y'all lol but to me that is overkill and to my ears the music doesn't sound right when the sample rate go beyond 48khz
                    uh!!
                    You must have a problem with your playback system.
                    Yes, the differences between hi-res and CD are negligible, but to say awful, is more nonsense.
                    • ForSerious
                      • Aug 2017
                      • 115
                      The bread and bones of digital audio quality can be found in this video.
                      More direct to the main question is this article.
                      I'm listing these from the same source because no one else seems to talk about all the relevant aspects in such a concise way.
