Asset UPnP R7
This topic is closed.
  • vilsen
    • Jul 2018
    • 156
    #46
    Re: Asset UPnP R7
    Hi GBrown! Were you using Mp3tag from scratch, not just to make the edit? Mp3tag writes TPE2 for AlbumArtist, and that as well as Album Artist works in R7.
    I'm interested cause I have a somewhat similar issue since last July which is related to the word album in the index file (described above).
    • GBrown
      • Oct 2009
      • 273
      #47
      Re: Asset UPnP R7
      Mp3 defines a specific tag for 'album artist' internally, it part of the standard. If you have a tag 'albumartist' then it is not using the standard tag, instead a program made up its own tag to store in.
      I use dbpoweramp, so the fields should rip correctly I would expect. Some older files were done in iTunes once upon a time, but that has not be done for some time.
      I have been using mp3tag for a pretty long time. But whether the mp3 files were ripped in iTunes or dbpa, I would have expected both to follow the standard. But I don't rip anything to mp3 any longer anyhow, so this is really a legacy issue for me. I am strictly ripping to lossless (ALAC for iTunes functionality), and have been slowly re-ripping my library. All files in this format were displaying correctly. So far this was the only consistent issue I was having in Asset.
      The fix was really pretty simple. I have just copied the contents of the current field "AlbumArtist" to a new field "Album Artist" using mp3tag. The file size difference in pretty small, it just means there are two duplicate fields in each file now. Again not the end of the world, and as I continue the really long task of going back over 15+ years of ripping CD's to lossless, eventually this won't matter.
      After a quick Refresh All in Asset, all is well in my library. Thanks for the support Spoon!
        • 43930
        #48
        Re: Asset UPnP R7
        Update to beta 4
        uMediaLibrary: cleaned up picture handling (webp is now supported),
        better integrity of filenamehash stuff - save in mid scan so it resumes where it died last time
        Added Frequency to default browse tree
        For control points which use Search to do album listings, the track order is based on track number
        New option on by default 'Album defined by folder' this means an album is unique to its folder it resides in
        Added crash reporter
        Added support for 'Work', 'Movement Name' and 'Movement Number' (itunes classical tags), can browse by Work, and will replace title with Movement Name and Track number with Movement Number.
        New browse tree item: Additional\Composer / Work\Work
        Added new possible browse tree item 'Album By Release (INV)' for an inverted listing, newest releases first
        Updated DSF and DFF presentation to audio/dsd (which Sony require)
        Codecs support HTTPS streaming
        • vilsen
          • Jul 2018
          • 156
          #49
          Re: Asset UPnP R7
          Beta 4 doesn't install in XP. No problems in Windows 10 except there's still the problem with indexing album type (or anything starting with album). The solution is the same as before, i.e. writing at least one character in the word album in upper case, e.g. alBum type.
            • 43930
            #50
            Re: Asset UPnP R7
            Vista is now the minimum version.
            • vilsen
              • Jul 2018
              • 156
              #51
              Re: Asset UPnP R7
              That's a pity. While I understand that XP is old, it's still the best Windows version when you need a lightweight OS for an offline server. I run Asset on a somewhat older laptop and Vista/7/8/10 are considerably slower and full of crap you don't need. Offline there are no security risks so XP is the optimal choice.
              • GBrown
                • Oct 2009
                • 273
                #52
                Re: Asset UPnP R7
                Update to beta 4
                Added this new 'Album By Release (INV)' to several tree items but it is blank in all cases. The 'Album By Release' works as expected. Full rescan after a reboot did not populate anything.
                Album Artist{_no_track_list_}{_a_to_z_}
                Album Artist\Album
                Album Artist\Album by Release
                Album Artist\Album by Release (INV)
                Album{_a_to_z_}
                Artist\Album
                Composer{_no_track_list_}{_a_to_z_}
                Composer\Album
                Composer\Album by Release
                Composer\Album by Release (INV)
                Genre{_no_track_list_}
                Genre\Artist
                Genre\Artist\Album
                Genre\Album
                Compilation{_no_track_list_}
                Compilation\Album
                Compilation\Album Artist{_no_track_list_}
                Compilation\Album Artist\Album
                Compilation\Composer{_no_track_list_}
                Compilation\Composer\Album
                Dynamic Browsing
                Dynamic Browsing\Artist{_a_to_z_}
                Dynamic Browsing\Composer{_a_to_z_}
                Dynamic Browsing\Conductor{_a_to_z_}
                Dynamic Browsing\Genre
                Dynamic Browsing\Style
                Dynamic Browsing\Year
                Dynamic Browsing\Rating
                TuneIn Internet Radio
                Playlists
                Additional
                Additional\New Albums
                Additional\New Tracks
                Additional\Recent Albums
                Additional\Recent Tracks
                Additional\Top Artists
                Additional\Top Artists\Album
                Additional\Top Albums
                Additional\Top Tracks
                Additional\Least Played Albums
                Additional\Least Played Tracks
                Additional\Jukebox Track Selection
                Additional\Jukebox Album Selection
                Additional\Album Artist / Album{_no_track_list_}{_a_to_z_}
                Additional\Album Artist / Album\Album
                Additional\Album by Release
                Additional\Album by Artist
                Additional\Compilation{_no_track_list_}
                Additional\Compilation\root
                Additional\Bits{_no_track_list_}
                Additional\Bits\root
                Additional\Contributing Artist
                Additional\Conductor{_no_track_list_}
                Additional\Conductor\root
                Additional\Rating{_no_track_list_}
                Additional\Rating\root
                Additional\Type{_no_track_list_}
                Additional\Type\root
                Additional\Year{_no_track_list_}
                Additional\Year\root
                Additional\Folders & Filename Browsing
                Additional\PC Sound Capture [WASAPI]
                Additional\Stream As
                Additional\Stream As\root
                Additional\[Details]
                New Albums
                Top Artists
                Top Artists\Album
                Top Albums
                  • 43930
                  #53
                  Re: Asset UPnP R7
                  Your tree works for me, try uninstalling Asset and installing the beta again.
                  • GBrown
                    • Oct 2009
                    • 273
                    #54
                    Re: Asset UPnP R7
                    Thanks, that did it. I had installed over the beta3 without uninstalling, as I thought that would lose my registration status. The INV works as expected now.
                    • Michael Sargent
                      • Dec 2009
                      • 134
                      #55
                      Re: Asset UPnP R7
                      Any chance we could get Channel count added, like Bits? I usually want to listen to surround recordings when I'm using Asset, and there is no easy way to do it.
                      Yes, I found a discussion on adding additional tags, but I have well over 100,000 tracks that would need to be updated. Since Bits is already supported, I have to think that adding support for Channels would be fairly straight forward (and a lot more convenient that requiring users to update all of their music).
                      Mike
                        • 43930
                        #56
                        Re: Asset UPnP R7
                        R7 already indexes channels, so add to the browse tree:
                        Additional\Channels{_no_track_list_}
                        Additional\Channels\root
                        • Michael Sargent
                          • Dec 2009
                          • 134
                          #57
                          Re: Asset UPnP R7
                          Excellent!
                          Thanks Spoon.
