SD-card vs. SD-card (help?)
  • monsterjazzlick
    • 1764
    Hi folks,
    I ordered a Sony NW-A45 Walkman from Amazon dot com recently. I am looking for a suitable SD-card to house circa 160GB FLAC albums.
    For my Amazon Fire tablet I use a SanDisk 200GB Micro-SD. This model was recommended by Amazon for my particular Fire device (it seems to be running fine as a means to storing/playing my FLACs from my tablet):
    There are many makes and models (Samsung seem to be quite popular) but I need, as I say, around 160GB; so it seems that, still, the 200GB is the best option. But should a SanDisk work OK with the Sony Walkman, do you think?:
    It says towards the foot of the Amazon page that Sony Walkmans and SanDisks are: "frequently bought together":
    Many thanks in advance for any kind assistance offered here.
    Paul
  • monsterjazzlick
    • 1764
    Re: SD-card vs. SD-card (help?)
    Someone once told me never to purchase a memory-card, or similar, from a private-seller on the likes of eBay because there is a possibility the items are not genuine! But if you buy direct from Amazon, or reputable retailer, then there is no risk.
      • 5750
      should work just fine.
      • monsterjazzlick
        • 1764
        You sound so sure! Actually, it works OK in the Amazon Fire; but I will try it out tomorrow in the Sony.
        What confused me was the many varying prices for, seemingly, the same thing?
          • 5750
          These things are made to a standard. For a legitimate vendor/brand anything thats large enough will work.
          • schmidj
            • Nov 2013
            • 500
            You do want to watch out. There are a lot of fakes out there. You'll see many large SD and particularly micro SD cards out there for very low prices. If the price is too good to be true it is... It turns out it is pretty easy to modify a small SD card so it reports that it is a very big one to your device. However, it is still a small one and can only hold the original amount of data. When you write more than that, it overwrites some or all of the original data.
            And yes there are fakes on Amazon: Read the reviews for this one.
            • monsterjazzlick
              • 1764
              Thanks a lot guys.
              I called Sony today (nearly 90 mins!) regarding which of SIZE SD-card is compatible with their A45 Walkman but the agent did not know. I was surprised because I did not anticipate this being a intricate question, by any means. He said he needed to escalate my question to a higher tier. Personally, I did not think that there was an upper-limit to the GB size you could use. In fact (partly my reason for phoning) I have read (in reviews) that the A45 could manage a 2TB SD!
              Cheers.
              • Jailhouse
                • Sep 2016
                • 388
                According to Crutchfield, the NW-A45 has "16GB internal flash memory, with up to 128GB additional storage (up to 144GB total memory)."
                Sony's own website doesn't indicate the maximum SD-Card size. That's sad.
                • schmidj
                  • Nov 2013
                  • 500
                  The 128 GB number was probably the largest micro SDHC card made when the copy was written, they don't want to say you could add 512 GB if you can't purchase a 512 GB card, deceptive advertising.
                  I suspect that any (legitimate) SDHC card you can buy will work (that has been my experience with smart phones), but your best bet is to try to find a Sony forum and ask there if anyone has tried what you want to use. Usually once they adopt the standard, (SDHC) it will work with any card properly implementing the standard. At least with audio, speed is not an issue. I have a 256 GB card in my cell phone, full. I'm waiting until the 400 GB cards become a little less pricey.
                  But obviously, this is only a suspicion on my part, absent trying one or a commitment from Sony, no guarantee!
                  • monsterjazzlick
                    • 1764
                    Thanks JH,
                    I never heard of 'Crutchfield' before.
                    Yes, it's difficult to ascertain a definitive answer from Sony! Quite absurd really. So I am waiting for a callback for conformation.
                    Paul
                    • monsterjazzlick
                      • 1764
                      Hi Schmidj,
                      The Sony forum is not that great, in my opinion. Plus, I much prefer posting such questions here as the traffic is busier and members seem to be more knowledgeable overall.
                      If the SD-Card limitation is 128GB, then I still might be able to fit most of my FLACs in by losing a couple of GENRES (eg. 'Self-Development') and utilizing the 16GB onboard storage facility for 1 or 2 other GENRES.
                      Paul
                      • monsterjazzlick
                        • 1764
                        Sony never called me as promised and so I had to chase them up. Ended up almost having an argument with them over the whole thing!
                        Basically, I was informed that the SanDisk SD-card (ie. loaded with FLACs for my Amazon Fire) is not being seen by the Sony Walkman device simply because it is not of their own 'brand' (ie. 'compatibility'). Their Tech Support guy said that the SD-Card needs to be a Sony model, and up to an upper-limit of 2TB. I searched high and low for one (online) whilst the guy was on the phone advising me of the various retailers who should stock them. I kept telling him that I could not see them anywhere? Then he checked with his Sales Dept. who informed him that they did not even exist! What a prat.
                        So in the end I found a Sony SD-card on Amazon (full circle!) which was 128GB:
                        The thing is, I can buy a SanDisk of 200GB for £20 cheaper - but he adamantly insists I must use/buy a Sony model. I have never heard of devices having to be matched with an SD-card of the same brand? He said if I buy a non-Sony brand then it is likely I will run into issues along the way, and thereafter their Tech. Support will refuse to assist. How's that for great customer-relations!
                        The guy is in no doubt I was highly cheesed-off with him; and I threatened to send the device back for a refund based upon his/their shoddy service.
                        Anyway, I am now left having to consider buying the above LINKED SD-card from Amazon tomorrow; and then Sony are calling me back on Friday to assist me with transferring all my FLACs to this storage device (because I said I would like assistance every step of the way so that they can not try to wriggle-out of anything, should anything go amiss).
                        Cheers,
                        Paul
                          • 5750
                          I would be shocked if a sony brand SD card was required. this makes no sense at all. Paul you really need to get out of the habit of contacting vendor support in most cases. As I've mentioned before, the odds of these folks actually providing any help, much less correct information is about zero. The help desk of these large companies are manned by people that typically know very little, read off a script, and often give out very bad information. It shouldn't be this way, but it is. You are much safer with a good google search and a crowd-sourced answer from real users (who many times actually know something). Just my two cents.
                          • monsterjazzlick
                            • 1764
                            Yes, I totally understand what you mean about call-centers etc. The fact that they always need to take-out 48 to find the answer before getting back to you says it all really. Although I do have to say that I am very surprised Sony has steeped this low.
                            But, unfortunately, the fact of the matter remains that I have tested out two non-Sony SD-cards and neither of them are working with the Sony Walkman! In this respect, I feel I am stuck between a rock and a hard place.
                            • schmidj
                              • Nov 2013
                              • 500
                              Paul:
                              The Sony guy is feeding you a line of CRAP! Any name brand (excluding the fakes) SD card is interchangeable with any other. There are differences of speed, mostly important with video, that are specified on the card. Any card you can buy will be fast enough to play back audio. And there is no such thing as a 2 TB micro SDXC card, at least yet. The biggest legit one available, if you can find and afford one, is 512 GB, 400 GB still pricey but more available. The cards all have to meet certain specs and be interchangeable to legally use the SDXC logo.
                              It is possible that the file structure is different on the Fire than the Sony. You might well have to format a card in the Sony and then copy the files to it. (a rather slow process). The user manuals for the two devices should be able to tell you what the file formats/structures are.
                              The fact that he mentioned 2 TB, which is, I think the largest they can eventually make an SDXC card with the addressing structure, would further imply to me that any size SDXC card (or SDHC or just SD, both less memory) will in fact be able to work.
                              I would avoid this customer service guy at all cost. What he is saying may be ignorance or it may be probably illegal tying of the brands.
