paid version not working with paid poweramp
    • 4015
    Re: paid version not working with paid poweramp
    Originally posted by Rein van der Me
    I did find Tags & Filenames.
    But nothing here
    the options button does not respond
    So to confirm, when you click the Options button to the right of Meta Data & ID Tag, nothing happens?
    ... also, in dBpoweramp Control Center (the dBpoweramp shortcut on the desktop), what Release is showing and what is the Registration Status showing?
    • Rein van der Me
      • Jan 2018
      • 19
      almost nothing
      quit strange
      the first file should be 52 mb, but it is actually 243 kb
      • Rein van der Me
        • Jan 2018
        • 19
        I changed the ripper method in secure and got his comment:
        Information ripping to FLAC, 'Track 1' to 'E:\Caravan muziek\Jos van Immerseel\Mozart; Clavier-Concerte 8, 28 & 12\01 Jos van Immerseel - Piano Concerto No. 8 in C major (-Lützow-) K. 246- Allegro Aperto.flac'
        Track 1: Ripped LBA 0 to 35120 (7:48) in 0:30. Filename: E:\Caravan muziek\Jos van Immerseel\Mozart; Clavier-Concerte 8, 28 & 12\01 Jos van Immerseel - Piano Concerto No. 8 in C major (-Lützow-) K. 246- Allegro Aperto._
        AccurateRip: Accurate (confidence 12) [Pass 1]
        CRC32: BC885AA4 AccurateRip CRC: 897D1BBA (CRCv2) [DiscID: 007-000f7e95-005d8fa5-6a0d4707-1]
        AccurateRip Verified Confidence 12 [CRCv2 897d1bba]
        AccurateRip Verified Confidence 8 [CRCv1 104422fb]
        AccurateRip Verified Confidence 7 [CRCv2 6f31f2e5], Using Pressing Offset -29
        AccurateRip Verified Confidence 7 [CRCv1 783c969], Using Pressing Offset -29
          • 4015
          almost nothing
          quit strange
          Set the flac compression level from the default level 5 to level 3 and try a re-rip.
          Reason here: dBpoweramp R16.4 & FLAC 1.3.2
          • Rein van der Me
            • Jan 2018
            • 19
            got a result now: a good track
            but what tot do next?
            got this information:
              • 4015
              #21
              Please reboot your PC and then confirm the following:
              01. In dBpoweramp Control Center (the dBpoweramp shortcut on the desktop)
              02. In CD Ripper Menu >> CD Ripper Options >> Tags & Filenames: Meta Data & ID Tag
              03. You are able to rip good tracks, when the flac compression level is 3?
              04. What security/anti-virus software is running, if any?
              05. What OS are you running?
              06. You are creating a log file, after ripping?
              • Rein van der Me
                • Jan 2018
                • 19
                #22
                16,4
                nothing happens
                yes, 3 - not 4 or 5
                Norton Security
                Windows 7
                only last rips - even if I changed back from secure to burst again
                and remember - there were no problems with the free version - with level 5
                  • 1749
                  #23
                  The flac compression problem is a newly problem within the free flac library, which isn't a product of Illustrate, but used by Illustrate. The version of the library might be different to the one in the registered version. As a first fix Spoon has released a beta version.
                    • 4015
                    #24
                    16,4
                    Release 16.4, 32 bit or 64-bit?
                    Further down the dBpoweramp Control Center wi is the Registration Status. Does this show as:
                    Reference Registered
                    Fully registered, no restrictions?
                    nothing happens
                    This is a real problem, as you are unable to access crucial CD Ripper options. Also, I have never come across this issue, ever. I hope Spoon is reading this and can shed some light on what might be going on here.
                    yes, 3 - not 4 or 5
                    This makes total sense. The trial version that you were using prior to the R16.4 installation, was using the Flac libraries v.1.3.1 or earlier. The R16.4 version which you are now using, installs the latest Flac libraries v.1.3.2 which have the bug explained here:
                    Norton Security
                    I suggest you disable Norton and try to re-install dBpoweramp R16.4 (maybe this will fix the issue in 02. above), but before you try this, please answer the 05. question below.
                    Windows 7
                    Windows 7, 32-bit or 64-bit?
                    Why are switching between Secure and Burst ripping methods?
                    Yes, see my answer in 03 above.
                    • Rein van der Me
                      • Jan 2018
                      • 19
                      #25
                      32 bit
                      fully registered, no restrictions (cant find bit number here)
                      I deinstalled and reinstalled again
                      now I can open options in the Tag & Filenames
                      I downloaded the beta version of Spoon and replaced the dll
                      that did not change anything
                      I changed from Burst to Secure and back just tot try something
                      If I read Spoons comment correctly I am the one client of 1.000.000 ;-)
                      • Rein van der Me
                        • Jan 2018
                        • 19
                        #26
                        in list/options of Poweramp it still says that Flac 1.3.2 is still used, but I can see that the dll is changed (newer version)
                          • 1749
                          #27
                          Do you see a folder C:\Program Files\dBpoweramp on your system? In which path did you exchange the dlls?
                          • Rein van der Me
                            • Jan 2018
                            • 19
                            #28
                            C:\Program Files\Illustrate\dBpoweramp\decoder
                            C:\Program Files\Illustrate\dBpoweramp\encoder
                              • 1749
                              #29
                              Did you change the default installation path during the installation? I'm asking cause the path "C:\Program Files" is an indicator for a 64 bit installation, while you wrote that you use the 32 bit version (usuallay in "C:\Program Files (x86)").
                                • 43978
                                #30
                                If the OS was 32 bit, then the mentioned paths would be correct.
