Genre / Style
  • monsterjazzlick
    • 1764
    Re: Genre / Style
    No, I wasn't even aware of it. Interesting.
    I think every track was UNRELEASED? There are no session notes, nothing in the CD sleeve, nothing on Wiki.
    Therefore, I think I will have to list PRODUCER, RECORDING YEAR, and VENUE as: 'UNKNOWN'.
    • Jailhouse
      • Sep 2016
      • 388
      Re: Genre / Style
      Looks like it. I figure it's a slapdash attempt to capitalize on Steely Dan's popularity.
      There are quite a few versions of this CD out there. I wonder how many of them, if any, are authorized.
      • monsterjazzlick
        • 1764
        Re: Genre / Style
        If all of the fields were totally blank, and, after I ripped the CD, the number in the ACCURATERIP column was (1), then does this indicate that I am the first person to have ripped this CD, please?
        It took ages to rip as it did so in 'frames'.
        • Jailhouse
          • Sep 2016
          • 388
          Re: Genre / Style
          It should mean that there was one rip in the database and that you got the same results. If there were nothing to compare to, each track would have been ripped twice and marked as Secure if the two rips produced the same result.
          Was the message, "CD in AccurateRip" at the bottom of the page before you started the rip?
          • monsterjazzlick
            • 1764
            Re: Genre / Style
            It did not state "Secure". I've seen that before so I would have noticed that.
            I can't remember if it stated "CD in AccurateRip" though.
            • Jailhouse
              • Sep 2016
              • 388
              Re: Genre / Style
              I sometimes wonder if I saw "CD in AccurateRip" or not while a rip is in process. One of those tricks of the mind.
              It looks like the next person will have two rips in the AR database to compare to.
              • monsterjazzlick
                • 1764
                Re: Genre / Style
                Maybe it will complete all of the track titles and artists names for the next person?
                • Jailhouse
                  • Sep 2016
                  • 388
                  Re: Genre / Style
                  Not likely. Our entries made before ripping don't update the databases CD Ripper uses to populate metadata. (There's a thread discussing that somewhere around here.)
                  • Oggy
                    • 697
                    Re: Genre / Style
                    Hi Paul,
                    As you say, submitting it to the database, will add confidence to the next person's rip; Accurate (2).
                    As previously mentioned, and suggested elsewhere, all we can do to help others, is use, Active Providers - Submit Changes to - freedb. I believe you do this, and hopefully over time, a couple of clicks submitting changes, will assist other users by improving the metadata available from freedb.
                    • monsterjazzlick
                      • 1764
                      Re: Genre / Style
                      Oh yes; I remember reading that middle of last year when I first joined here.
                      • monsterjazzlick
                        • 1764
                        Re: Genre / Style
                        Originally posted by Oggy
                        Hi Paul,
                        Thanks Oggy, I always submit my data to the database. I have set it to do so on a daily basis.
                        • Oggy
                          • 697
                          Re: Genre / Style
                          Hope this isn't too far off thread, but do you submit to freedb, too? I've recently ripped a couple of boxsets of well known artists, The Allman Brothers Band and Traffic, and was surprised that no composers showed up, so submitted them. As two or three of these are very well known albums, I guess that earlier pressings may well have the composer metadata.
                            • 5744
                            Re: Genre / Style
                            someone mentioned elsewhere (I think) that freedb database doesn't keep track of composer tag field.
                            • Oggy
                              • 697
                              Re: Genre / Style
                              Ok, missed that one, so many thanks, and that would certainly explain the missing Composer tag field. Does seem a shame that there is no easy way of sharing metadata, that people have taken the time to populate.
                              • monsterjazzlick
                                • 1764
                                Re: Genre / Style
                                Hi Oggy, I don't submit to freeb at present. It's something I have not configured. Cheers.
