Re: RE: You Tube Grabber (help?)
    • 5746
    Re: You Tube Grabber (help?)
    I watched some tutorials on 'Audacity' and tried to make the CD edit using only this s/w.
    I split the tracks and exported. But even though all of the tracks are correctly numbered (1-5), they only appear in alphabetical order (rather than by respective track number?):
    [ATTACH=CONFIG]1838[/ATTACH]
    [ATTACH=CONFIG]1839[/ATTACH]
    I am not sure why this is, please?
    Thanks a lot,
    Paul
    no clue. But this is an audacity question. They have a forum:
    • monsterjazzlick
      • 1764
      https://forum.audacityteam.org/
      Gary,
      I just joined a posted a question. Because I am new it needs to be moderated first.
      I am not entirely sure if the issue is with Audacity?
      Cheers,
      Paul
      • Jailhouse
        • Sep 2016
        • 388
        Appear where? (I can't see your attachments yet.) If in Windows Explorer, do your file names start with track numbers? If in foobar, have you tagged the files?
        • monsterjazzlick
          • 1764
          Hi JH,
          My pics never seem to show?! Please try these via Drive:
          Screenshots show Windows and Foobar.
          Cheers,
          Paul
            • 5746
            Do the file names themselves start with track number, ie 01 - name of song.flac, 02 - name of song.flac, etc.
            also in foobar if you click on the track number column heading, it should sort by that and display in track number order.
            • monsterjazzlick
              • 1764
              #21
              ... ID Tag:
                • 5746
                #22
                Im not asking about ID tags. My question was regarding the actual file name you see in Windows explorer.
                • monsterjazzlick
                  • 1764
                  #23
                  Thanks Gary,
                  I will check.
                  Strangely, the Folder (art) appears above all of the FLACs (in the album folder); yet in every other CD I have ripped it sits underneath them.
                  Paul
                  • monsterjazzlick
                    • 1764
                    #24
                    I think we both replied at exactly the same time, hence I missed this response.
                      • 5746
                      #25
                      Thanks Gary,
                      I will check.
                      Paul
                      I think more evidence that your file names do not start with track number.
                      • monsterjazzlick
                        • 1764
                        #26
                        Got it now thanks.
                        I think its working OK having made the changes:
                        To be honest, I have never really looked at how the files appear in Windows since moving over to Illustrate and Foobar.
                        Paul
                        • monsterjazzlick
                          • 1764
                          #27
                          Evidently correct!
                          • monsterjazzlick
                            • 1764
                            #28
                            Now that the album is in FLAC and also track marked, is it possible for me to apply 'Replay Gain', please?
                            Paul
                              • 5746
                              #29
                              Paul
                              Yes. Just convert album tracks to Utility dsp Replay Gain. This will write RG tags.
                                • 5746
                                #30
                                See post no 8 here
                                Before I began ripping my CD collection losslessly, it was all mp3. This is what my iTunes library consists of. A big problem, identified by others, is that recent editions of iTunes won't save volume adjustments for individual songs (under Get Info, with the slider). So a few years back I wasn't happy with the volume of my
