RE: Defining 'Digitally Remastered' (help?)
  • monsterjazzlick
    • 1764
    Hi folks,
    I wanted to ask something regarding 'Digitally Mastered' CDs, please.
    If an LP (say, something from: 'The Beatles' repertoire) is released in CD format (eg. in 1999), then does format this qualify as falling under the umbrella of being: 'Digitally Remastered'? Obviously it is in a 'digital' (binary) form.
    What I mean is, would it be automatically classed as: 'Digitally Remastered' simply because it is an LP which has been transferred to CD?
    I always wondered if the term: 'Digitally Remastered' meant that it is the 'Digitally Remaster' of an already released CD. For example, if a 'Beatles' LP was released on CD in 1999, and then a second CD (identical in content) released in 2009, then I was thinking that it is the latter CD which has been 'Digitally Remastered'. For instance, they could have digitally enhanced the first 1999 CD release using newly available technology (hence the term: 'remastered')?
    What has partly prompted this question is that I have a very small handful of duplicate CD titles (though the newest releases feature bonus material - which was my reason for purchasing it!). On the older CD cover there is no mention of it being a 'Digitally Remastered' version; but on the newer CD covers it is boldly stated loud and clear?!
    Many thanks,
    Paul
    • 4015
    Re: Defining 'Digitally Remastered' (help?)
    No. It could be digitally mastered, i.e. the original masters will be used as the source for the CD or it could be re-mastered where, the original masters will be enhanced before digitally mastering.
    So, an album may be re-issued at a later date, but it does not mean it has been re-mastered.
    • monsterjazzlick
      • 1764
      Thanks mville,
      Bare with me please.
      So 'remastered' is not exclusively a 'digital' (world) term? I mean, if an LP was released in 1940 then could it be remastered 'analogly' in 1960 and released on LP again?
      Cheers,
      Paul
      • Jailhouse
        • Sep 2016
        • 388
        Here's some reading material:
        Wikipedia: Remaster
        How Stuff Works: What does 'digitally remastered' mean?
        • monsterjazzlick
          • 1764
          Cheers JH. I will have a read tomorrow. Hopefully it won't be too difficult to understand! Thanks, Paul
            • 4015
            Correct, but there a few studios today, that are totally analog.
            Yes, but nowadays this is extremely rare.
            Often, the original analog master tapes are transferred to the digital domain. Then, these maybe re-mastered or even re-mixed and finally the vinyl is cut from the digital masters. Just take a look at the recent packages for the Giles Martin 2017 Sgt. Pepper's Lonely Hearts Club Band release.
            • monsterjazzlick
              • 1764
              Cheers mville,
              But I was kinda thinking in terms of literally us being in the year 1960 (as opposed to now). So would the reissue of a 1940 LP in 1960 be classed as a (analog) remaster?
              Paul
                • 4015
                Only if the 1940 master tapes were re-mastered, but how would anyone know? I doubt this info was published back then.
                The way I look at these things is, if an album is re-released at a later date and I know it has been re-mastered, then I add remaster to the album otherwise, I assume it has not been re-mastered and add re-issue.
                e.g. I have 2 versions of David Bowie - David Live, originally released in 1974:
                David Live (2005 Re-Issue) and David Live (2016 Remaster)
                • monsterjazzlick
                  • 1764
                  OK, cheers mville.
                  So you really do make a clear distinction between a re-master and a re-issue; and this is reflected in your tagging.
                  Paul
                    • 4015
                    Yes.
                      • 1748
                      Hey Paul,
                      BTW: it ain't necessary and is not usual to start every topic with a leading "RE: ". In fact it's irritating 'cause "RE" stands usually for "reply".
                      • monsterjazzlick
                        • 1764
                        Hi, I always thought it meant: "with reference to"? Cheers.
                          • 1748
                          Hey Paul,
                          it doesn't matter if it is "reply" or "reference to" - it is unusal and not common to start thread titles with "RE: ", as you can see i.e. in this forum. The topic should speak for itself.
                            • 5744
                            Yes, in letters and memos, but NOT in emails or forum posts.
                            • monsterjazzlick
                              • 1764
                              OK, cheers.
