Error converting to [Multi Encoder], 'Track 1' to 'no_filename_specified_1' ...
  • flips
    • Jan 2006
    • 93
    Did a rip with my usual setup, Multi Encoder, using the AAC encoder with two different settings.
    Just upgraded to 16.1 for Mac. Ripped a CD, then got these errors. (Doesn't bother me, thought you'd like to know ...)
    The ripped files seems to be perfectly OK, no trouble as far as I can tell, so I don't know what exactly the error means.
    Maybe the Multi Encoder tried doing something in addition to what each encoder did ... or something.
    Code:
       Error renaming 'no_filename_specified_1._' to 'no_filename_specified_1' (code: 2).
    Error converting to [Multi Encoder], 'Track 2' to 'no_filename_specified_2'
       Error renaming 'no_filename_specified_2._' to 'no_filename_specified_2' (code: 2).
    Error converting to [Multi Encoder], 'Track 3' to 'no_filename_specified_3'
       Error renaming 'no_filename_specified_3._' to 'no_filename_specified_3' (code: 2).
    Error converting to [Multi Encoder], 'Track 4' to 'no_filename_specified_4'
       Error renaming 'no_filename_specified_4._' to 'no_filename_specified_4' (code: 2).
    Error converting to [Multi Encoder], 'Track 5' to 'no_filename_specified_5'
       Error renaming 'no_filename_specified_5._' to 'no_filename_specified_5' (code: 2).
    Error converting to [Multi Encoder], 'Track 6' to 'no_filename_specified_6'
       Error renaming 'no_filename_specified_6._' to 'no_filename_specified_6' (code: 2).
    Error converting to [Multi Encoder], 'Track 7' to 'no_filename_specified_7'
       Error renaming 'no_filename_specified_7._' to 'no_filename_specified_7' (code: 2).
    Error converting to [Multi Encoder], 'Track 8' to 'no_filename_specified_8'
       Error renaming 'no_filename_specified_8._' to 'no_filename_specified_8' (code: 2).
    Error converting to [Multi Encoder], 'Track 9' to 'no_filename_specified_9'
       Error renaming 'no_filename_specified_9._' to 'no_filename_specified_9' (code: 2).
    Error converting to [Multi Encoder], 'Track 10' to 'no_filename_specified_10'
       Error renaming 'no_filename_specified_10._' to 'no_filename_specified_10' (code: 2).
    Error converting to [Multi Encoder], 'Track 11' to 'no_filename_specified_11'
       Error renaming 'no_filename_specified_11._' to 'no_filename_specified_11' (code: 2).
    Error converting to [Multi Encoder], 'Track 12' to 'no_filename_specified_12'
       Error renaming 'no_filename_specified_12._' to 'no_filename_specified_12' (code: 2).
    Error converting to [Multi Encoder], 'Track 13' to 'no_filename_specified_13'
       Error renaming 'no_filename_specified_13._' to 'no_filename_specified_13' (code: 2).
    Error converting to [Multi Encoder], 'Track 14' to 'no_filename_specified_14'
       Error renaming 'no_filename_specified_14._' to 'no_filename_specified_14' (code: 2).
    Super Moderator
    • 1368
    Re: Error converting to [Multi Encoder], 'Track 1' to 'no_filename_specified_1' ...
    Bug fixed for upcoming 16.2 beta, thanks for reporting.
    From the looks of it, the bug is indeed harmless, the error messages can be safely ignored.
      Super Moderator
      • 1368
      Beta version posted-
      This is a bug-fix release addressing reported bugs from R16.1. Current version: R16.2 beta 7 Download: <Released> Changes since R16.1 Fixed Apple AAC encoder bitrate slider glitch CD Ripper can now deal with discs having 98 or 99 tracks. CD Ripper fixed spurious file rename error messages sometimes appearing when
