Accuraterip does not recognize my external CD drive
  • RNI61
    • Apr 2017
    Hi all
    I just bought a new laptop (Asus) and it has no internal CD drive. Got an external drive on USB (Asus also). DBpoweramp works well with this (recognized in seconds), however Accuraterip state s my drive as "unknown" when asking for a key disc. I've tried with 3 different disc's same result. My rips are not verifyed with Accuraterip, but "secure". Take twice the time :-(
    Further info: I connect my drive in the USB 3 port, even it's a USB 2 drive. Does this matter?
    Thanks in advance for your help.
    Kind regards: René from Denmark
    • 43997
    Re: Accuraterip does not recognize my external CD drive
    You can try a different drive? no drive should appear as (unknown), that just means the drive is failing the most basic of requests (to return the drive name).
    • RNI61
      • Apr 2017
      Thanks for your reply. Perhaps I wasn't clear enough (my mistake). It is "unknown" to Accuraterip, it's recognised in Windows 10, and in DBpoweramp (Version 16.2), by it's name. No problem there. I do not have any spare drive to test with.
      Maybe the solution is to buy an internal and install it myself :-(
      Anyway, thanks for your concern.
        • 5753
        I would keep trying with common CDs. Sometimes it can take 10 to 20 CDs before setup.
        • RNI61
          • Apr 2017
          I will do that. Patience is not my strongest side :-)
          Thanx.
          KR: René
