Problem converting WAV files to FLAC
  • Oldhumhead
    • Aug 2016
    I just upgraded to the latest version of Reference and tried to convert an 88.2/24 WAV file to FLAC but MC returned the message: "Error FLAC accepts only PCM audio source [dEncoder:BeginConversion]". I'm running Win10 Pro/64-bit with AMD 8-core proc and used default settings on MC. Another converter program I tried converted the file but dumbed it down to 44.1/16. Any help would be appreciated. Thanks.
    • 43930
    Re: Problem converting WAV files to FLAC
    The file must be 32 bit float which is incompatible with FLAC, use the DSP Effect 'Bit depth' whilst converting to flac and choose the 24 bit option.
    • Olhumhead
      • Aug 2016
      Thanks for your prompt response. Your advice worked like a charm.
