WAVE codec settings for List /ID3 tagging options not working in OSX?
  • MacUser
    • Jun 2016
    Hello, I can only find anything via the main Configuration > Codecs > Advanced Codec Options panel but changes here are not reflected in Batch Converter?
    • 43927
    Re: WAVE codec settings for List /ID3 tagging options not working in OSX?
    What option are you selecting specifically? does the setting stick so next time you visit the Advanced Codec Options it is set correct?
    • MacUser
      • Jun 2016
      The first one tried was to select Tag Creation = ID3, this (and others) does persist after re-loading the application but the selection is not actually implemented?
      • MacUser
        • Jun 2016
        So, is this a bug please?
          • 43927
          It is being investigated.
            Super Moderator
            • 1365
            Thanks for the bug report.
            A new update - R15.6 - will be posted shortly, it contains a fix for this bug.
            • MacUser
              • Jun 2016
              Thank you for sorting this out.
                Super Moderator
                • 1365
                Sorry about the delay. The R15.7 beta got deployed internally but apparently I forgot to post it where it belongs.
                Anyway, here it is:
                This is the last planned part of R15 lifetime. All new features go into R16. R15.7 contains only critical bug fixes. Current version: beta 3 Changes since R15.6: Fixed DSP preset save button triggering the wrong action. Fixed crash when last used codec does not exist [after running R16 alpha versions]. Fixed codec options
                Direct download link:
