[codec] DSD Decoder R3
    • 43928
    #31
    Re: DSD Decoder R3
    It is odd that you have the 64 bit version installed to the 32 bit location, you would be best to uninstall dBpoweramp and any codecs, then reinstall.
    • GaryWW
      • Aug 2012
      Re: DSD Decoder R3
      So when I reinstalled dBpoweramp, the 64-bit installer ran but I had to tell it install into C:\Program Files\Illustrate\dBpoweramp. When I ran "dBpoweramp-Codec-DSD-SACD.exe", the 64-bit installer ran and it was installed properly.
      Gary
