Volume Normalizer + Low Pass Filter (or Low Pass Filter and then Volume Normalizer)?
  • Dallaed
    • Jul 2014
    • 29
    HI !
    I am converting Flac to Mp3 (320 Kbps).
    Please, what is the correct: First Volume Normalizer and then Low Pass Filter or the opposite (Low Pass Filter and Then Volume Normalizer)?
    Thanks and Regards !
    Dallaed.
    • 43930
    Re: Volume Normalizer + Low Pass Filter (or Low Pass Filter and then Volume Normalize
    Low Pass then Normalizer
    • Dallaed
      • Jul 2014
      • 29
      HI, Thank you for your support.
      Please, just another question: Is 20.000 Hz a good set frequency for low pass filter or 21.000 would be better (I am converting flac to 320 Kbps CBR mp3)?
      Dallaed
      Last edited by Dallaed; 07-27-2014, 08:45 PM. Reason: Editing my previous question
        • 43930
        There is no need to low pass, it is the encoder which will low pass its self, your low pass would have no effect on the encoder.
        • Dallaed
          • Jul 2014
          • 29
          Thanks again.
          Hum....I believe this will be the final question: EBU R128 (track) X Replaygain (track). Which is better for DSP "Volume Nomalizer" regarding my FLAC to MP3 320 Kbps CBR Converter?
          Thanks !!!
            • 43930
            EBU R128 is the newer standard.
