Volume Normalizer + Low Pass Filter (or Low Pass Filter and then Volume Normalizer)?
  • Dallaed
    • Jul 2014
    • 29
    HI !
    I am converting Flac to Mp3 (320 Kbps).
    Please, what is the correct: First Volume Normalizer and then Low Pass Filter or the opposite (Low Pass Filter and Then Volume Normalizer)?
    Thanks and Regards !
    Dallaed.
    Re: Volume Normalizer + Low Pass Filter (or Low Pass Filter and then Volume Normalize
    Low Pass then Normalizer
    • Dallaed
      • Jul 2014
      • 29
      HI, Thank you for your support.
      Please, just another question: Is 20.000 Hz a good set frequency for low pass filter or 21.000 would be better (I am converting flac to 320 Kbps CBR mp3)?
      Dallaed
      Last edited by Dallaed; July 27, 2014, 08:45 PM. Reason: Editing my previous question
        There is no need to low pass, it is the encoder which will low pass its self, your low pass would have no effect on the encoder.
        • Dallaed
          • Jul 2014
          • 29
          Thanks again.
          Hum....I believe this will be the final question: EBU R128 (track) X Replaygain (track). Which is better for DSP "Volume Nomalizer" regarding my FLAC to MP3 320 Kbps CBR Converter?
          Thanks !!!
            EBU R128 is the newer standard.
