a returning bug in dmc cd audio input
  • Razgo
    • 2532
    i thought my ogg got broken! when i read this error: The output file '\\CdRom\Enigma\MCMXC a.D\Enigma - The Voice & The Snake.ogg' could not be opened.
    i can't quite pinpoint how or why but for some reason when ripping a cd it will choose "same folder as original".
    if i use the choose the rip to ogg and then select rip with right click option everything is fine. but then select flac from the drop down menu to change the codec and boom it switches to "same folder as original".
    visa versa also happens.
    it is inconsistant and you will see some codecs will switch to "same folder as original" and others are ok. but then make the rip option different then a different set of codec will produce this bug. it's like something gets stuck.
    • 43930
    Re: a returning bug in dmc cd audio input
    Noted.
