Trouble converting a file (I know what caused the problem, but not the solution)
  • Zao
    • May 2014
    • 15
    Hi. I use Winamp to listen to my music, and at the time was using a plugin called "ID3 Tray Rate". This plugin allows you to simply edit the rating of an audio file, stored in the ID tag/Metadata. It hasn't caused me any problems before. But with this one specific file, it caused it to not work with Winamp or Windows Media Player. It will play with VLC though.
    I also am not able to convert the file with dbpoweramp. Whenever I try, I just get this message:
    "Error converting to Wave, Error RIFF chunk unknown 'ID3' [clRIFFHandler::ScanFile]"
    I have stopped using that plugin, and the file in question is Wave format. I have tried editing the tags with dbpoweramp. But it says that the file has no ID tags. I can't add any either, apparently.
    Any ideas what has happened to the file, and how I might fix it? I was hoping that dbpoweramp might somehow be able to reset the ID tags or something. I'm guessing they're the problem.
    • 43930
    Re: Trouble converting a file (I know what caused the problem, but not the solution)
    Please email one such file:
    • Zao
      • May 2014
      • 15
      http://www.dbpoweramp.com/email.htm
      "The following email address is provided for non-support enquiries only (any registration questions, use the email address below), support questions should be directed to the Forum"
      • Zao
        • May 2014
        • 15
          • 43930
          It is ok, we are expecting your email.
          • Zao
            • May 2014
            • 15
            Ok, cool haha
            • Zao
              • May 2014
              • 15
              Sorry to double post. But I have sent the email. And just to add to the info here - I don't seem to be able to add the "Album Artist" tag to my wave files. I've been trying it on various wave files I have (ones that have never been affected by the ID Tag plugin I mentioned). Not sure why. It works with other file formats like FLAC (which I normally use). I have tried installing the WavPack and Wave64 codecs just for the sake of trying them. But they didn't help.
              Any ideas?
              Maybe I'll try reinstalling dbpoweramp in a bit. I'll let you know if it helps. Thanks
              • schmidj
                • Nov 2013
                • 499
                Regarding the "Album Artist" issue with .wav files, I had the same problem a few months ago, and Spoon had the reason and solution. Here is a link to the forum thread: http://forum.dbpoweramp.com/showthre...ndows-Explorer His solution solved my issues.
                  • 43930
                  This issue is this program has simply written an ID3 chunk to the start of a wave file, this corrupts the file because wave is chunk based.
                  • Zao
                    • May 2014
                    • 15
                    So I have to convert the wav files from LIST to id3? I already have the id tag update installed. But I don't know how to convert the files to id3 format. Can you help with that? Thanks!
                    Is this in reference to my original question? If so - is it beyond repair? Thanks!
                    • Zao
                      • May 2014
                      • 15
                      Looks like the reply I wrote earlier didn't post :(
                      @schmidj - The solution was to convert from LIST to id3? Could someone explain how to do that please? Thanks!
                      @Spoon - Is that in reference to my original post? If so, is the file recoverable? Thanks!
                        • 43930
                        dBpoweramp cannot recover this file.
