repeated song conversion
  • wilejoe
    • Mar 2014
    • 10
    A good day to everyone.
    I'm having a problem converting my flac files.
    I recently purchased and downloaded a few RatDog shows .
    The shows are usually 3 cds long.
    I tried to convert the shows to wave in order to burn them onto a cd to play in my cd player.
    The problem I have is when the band starts a song jams into another song and then goes back to the original song
    ex. just like mama said
    milestones
    just like mama said
    Either the first or the second "just like mama said" is converted the other one is just ignored
    So instead of having 21 songs I only have 20
    Is there a way to fix this
    Thanks in advance for any help :smile2: Joe
    • 43930
    Re: repeated song conversion
    They must have the same filename, which naming string are you using for conversion? are the discs being converted to separate folders?
    • wilejoe
      • Mar 2014
      • 10
      First off am I using the right program or should I be using the music converter.
      I am unfamiliar with how to use the music converter, is their any instructions I could follow.
      I am not keeping these new wave files , I am only using them to burn a disc and then I delete the wave files
      Secondly I am trying to learn how to use the naming strings and where to find them.
      Thanks once again
      Joe
        • 43930
        Music Converter is the right program. Convert each disc on its own, if you see a message asking to overwrite a file then you know this is the issue.
        • wilejoe
          • Mar 2014
          • 10
          Ok I'm still stuck
          I renamed the first song 03 1 Just Like Mama Said
          and the next time 05 Into Just Like Mama Said
          3rd and 5th song on cd respectively
          And its still omitting the first Just Like Mama Said when I convert
          What am I doing wrong
            • 43930
            What output filename have you set? on the conversion page?
            • wilejoe
              • Mar 2014
              • 10
              [artist]\[artist] - [title] wave
              and dynamic is checked
                • 43930
                This is why, you can keep the original filename with:
                [origfilename]
                or you could put track number in there:
                [artist]\[artist] - [track] - [title]
                • wilejoe
                  • Mar 2014
                  • 10
                  thanks
                  Worked like a charm
                  I knew it had to be something easy
                  I did [origfilename] wave
                  It kept original flac file and added a wave file just like I wanted
