Batch Converter Removes Parts of Tracks
  • BellMO84
    • Jan 2014
    I am fairly new to this program. I have not had any issue until recently. I went to convert 320 mp3 files to 252 mp3 files. Most seem to work except for some shorter interludes. There is one that is 5 seconds long with two lines in it. Once it's converted the file becomes 2 seconds long, with only half of the last line playing... Can this be fixed?
    • 43928
    Re: Batch Converter Removes Parts of Tracks
    Possibly our decoder is finding an error in the file, if you enable the information log it should say if it had a decoding error.
    • BellMO84
      • Jan 2014
      Thanks. Could you explain how to enable the log, and I can give it a try?
      Edit: I got it fixed. I re-downloaded the files from another source, and it worked just fine.
