How to calculate ReplayGain without reencoding?
  • starcat
    • Aug 2017
    Re: How to calculate ReplayGain without reencoding?
    Where is the Batch Converter?
    Also, how can I remove the Album and Track Gain tags (in case I wanted to)?
    Is there a quick option? Thanks again.
      • 43964
      Batch Converter is installed with dBpoweramp, select the start menu and type:
      Batch Converter
      There is a utility codec called 'ID Tag Update' you could use this with Batch converter to delete selective tags.
      • starcat
        • Aug 2017
        Got it! Very nice, thanks!
        • starcat
          • Aug 2017
          Spoon, the word "conversion" makes me a bit nervous, thus asking again. By "conversion" to ReplayGain Codec there is absolutely not any conversion whatsoever going on over the audio data stream, only the data is calculated for the ReplayGain values and written to the respective tags into the audio files, right? Thanks again for confirming!
            • 4015
            Correct, the Replay Gain R5 utility codec is non-destructive.
