possible bug in audio cd input option box
  • Razgo
    • 2532
    the is something strange happening. my tick boxes arn't working properly.
    they will work when the initial screen is open but when i move the scroll bar down you cannot put a tick directly in the box. you have to click below the box for the tick to appear in the above box. also the tick won't stay on in the AR part. i am trying to reset/configure AR.
  • donny
    • Oct 2002
    • 761
    Re: possible bug in audio cd input option box
    is this because of your problems with the acuraterip.dll? I have looked in my folders - it is also mising now that I have installed rc1.1
    • Razgo
      • 2532
      no, but putting back the accuraterip dll file allowed me to get accuraterip working again.
      but the ticks don't work properly of i move the scroll bar down on the right.
      can you put the ticks in and out if you scroll your bar down?
      if i scroll back up i can put ticks in and out correctly.
      oh and is your accuraterip enabled? configured?
        • 43930
        Yes it is a bug.
        • Razgo
          • 2532
          whoohoo! i found a bug :D , i have to say it is very difficult to find a bug these days.
