Problem with Disc Publisher Pro (Unable to locate Primera robot)
  • mcandrle23
    • Nov 2013
    • 10
    Re: Problem with Disc Publisher Pro (Unable to locate Primera robot)
    Selecting the Loading method: Primera
    It has only one test Load CLI
    Beginning Test
    Running Program: "C:\Program Files\Illustrate\dBpoweramp\BatchRipper\Loaders\Pr imera\Load\Load.exe" --stoponmultidiscsloaded="yes" --drive="F" --logfile="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\dBB5A7 .tmp" --passerrorsback="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \dBB5A8.tmp"
    Running...
    Primera Looking For Drive:F
    Primera PTRobot_Initialize: EnumRobots: EnumDrives Robot *0: *** Error: Unable to locate Primera robot containing drive 'F', please check connection.
    PTRobot_Destroy: Destroyed
    Testing Complete
    Results:
    The Expected CD Drive door opened.....
      • 43928
      You have the printer driver installed?
      Hi folk, I have a Problem with a Primera Disc Publisher Pro. I installed everything, drivers, original Primera software (PTPublisher - btw it is working with the Robot), dBpoweramp Reference, Batch Ripper R1.5 and Primera Batch Ripper Driver R3.0.2. But if I start the "Test" in "dBpoweramp Batch Ripper:
      • mcandrle23
        • Nov 2013
        • 10
        Yes, I saw that in the thread, and checked that the printer is wokring
          • 43928
          I am not sure what else I can suggest, sorry.
          • mcandrle23
            • Nov 2013
            • 10
            Is this the only level of support? Your ripping product seems to resolve a problem others have in that I can enter my own META data for CD Sets. The CDDB will not have all my CDs listed so can't use the PTRip app that is with PTPublisher, the vendors' application that works the robut just as expected.
            I had expected the directory struction you created, C:\Program Files\Illustrate\dBpoweramp\BatchRipper\Loaders\Pr imera\Load to be able to simply run the "load.exe" program and have it load up a CD onto a tray, well, no this is not the way it works, but should it have?
            I purchased your product for its ability to manually enter META data, confirmed that was going to work as I needed it to then purchased a used Disc Duplicator Pro robot because it was said to be supported by your application. Lot of time and money invested, need to continue forward.
            • RipIt
              • Oct 2013
              #21
              At the Moment i am quite bussy but if I will find some time i will try it again on an other system / computer. I will report my progress...
              • mcandrle23
                • Nov 2013
                • 10
                #22
                Just how is the robot communicated with, will the batch prgram simply launch the programs:
                C:\Program Files\Illustrate\dBpoweramp\BatchRipper\Loaders\Pr imera\Load Load.exe with the "DefaultCmdLine.txt"?
                Can each of the Load, pre-batch, reject and unload apps be run from the command line in order to confirm their operation independent of the ripper application?
                  • 43928
                  #23
                  Yes they can, but it will not help you, as the test program runs them in that way, you can see the command line passed to this programs.
                  • mcandrle23
                    • Nov 2013
                    • 10
                    #24
                    I went on the site for PTPublisher, downloaded their development files and looked at:
                    10/28/2011 12:53 PM 3,473,408 PTRobot.dll
                    10/28/2011 01:24 PM 1,640,448 PTRobot4100.dll
                    11/04/2013 03:30 PM 1,574,400 PTRobotApp.exe
                    10/28/2011 01:16 PM 1,625,600 PTRobotDP.dll
                    10/28/2011 01:16 PM 1,636,864 PTRobotDPPRO.dll
                    10/28/2011 01:16 PM 1,631,744 PTRobotDPse.dll
                    11/04/2013 03:30 PM 390,656 PTRobotStr.dll
                    The PTRobotApp runs the robot just fine moves the disks in any way I select. It seems you are using the same DLLs at least by their name, sizes are different. Just another confirmation that the communcations between my computer and the robot are just fine, and getting closer to that you had done in interfacing your app with the robot.
                    • mcandrle23
                      • Nov 2013
                      • 10
                      #25
                      You talk of the "Test" program and I assume you are talking ot the Loader Configuration app. There are 5 actions, Load CLI, Unload LCI, Reject CLI Pre-Batch CLI and Post-Batch CLI When I selected the "Loading Method Primera" there is only one line populated Load CLI with [--stoponumultidiscsloaded="yes"] with a comment under it "If 2 Disks are picked, will wait for the user to click ok"
                      Question: Shouldn't there be something in each of the five options to test?
                        • 43928
                        #26
                        Try replacing our dlls with the newer ones you have downloaded.
                        • mcandrle23
                          • Nov 2013
                          • 10
                          #27
                          Yes, that is what I had done, and yes it now works. So now with a small script I completed in AutoIt I can fill in the MetaData with my own information from a small text file, rather then looking it up. I can now begin the process of archiving my book collection
                            • 43928
                            #28
                            Please email these dlls:
                            and we will update our install.
                              • 43928
                              #29
                              Clear off the old driver and give this version a go please:
                              This update should fix the issues people are seeing with modern Primera units not being found. <now released> 29MB
