ac3 sound support ???
    I know we can decode ac3 streams to wav or mp3 or whatever, but I'd like to make a stereo ac3 file from a 2 channel wav or mp3 file. Is it possible with dbpoweramp or does someone 'need' to make a codec for it ????
    • 43929
    Someone would have to make a codec.
    • auenf
      • Aug 2002
      • 17
      ac3 encoders start at US$1k, i dont think anyone would make a properly working ac3 encoder 'codec' for dbpoweramp.
      about the closest is besweet/azid which also say that the ac3 encoder is experimental and is known not to work properly
      Enf...
        Re: ac3 sound support ???
        www.ac3dec.com has a winamp plugin to decode ac3 files. It'll work on unencrypted vob files also.
