I found a problem on DAP 3 beta 3
  • djben
    • Jul 2003
    • 23
    I have a keyboard, microsoft multimedia wireless keyboard, and my button +/-, for the volume, doesn't work with windows after installing DAP, even when DAP, is closed, can you help me over here ??? what can I do, to make it work with other player, such as video player, like the playa, or windows media player
    thanks....
  • Joseph
    • Oct 2002
    • 211
    Did your Keyboard come with a Driver? If not maybe there is some manufacturers website that has a driver update that will fix your problem...
    • donny
      • Oct 2002
      • 761
      dAP can assign these keys to it's own volume - so even when it's off the keys won't change the master volume...
      Only I'm not sure is this automatic or not (the assigning)
      Anyway checkout start->programs->dbpoweramp->configuration->keyboard control just to be sure.
      • RossRoy
        • May 2003
        • 403
        I had that same problem, dAP would just take control of my volume control on my keyboard and I totally lost control of the master volume that way.
        You could try assigning the volume controls to other jeys but I doubt it'll change it, seeing as Windows doesn't see the volume knob as a key per-se.
        The only way I found to fix the problem is a very drastic solution. I deleted the DLL file in dbPowerAmp that binds itself to the key buffer to intercept them. I think the file was called dapkeycontrol.dll but I am not 100% positive about the exact name of it, but you can't miss it. You will probably have to reboot in DOS or in Safe Mode to delete it, or else Windows tells you that the file is in use.
        *** BE WARNED THAT IF YOU USE YOUR KEYBOARD TO CONTROL DAP WHILE IT IS NOT THE FOCUSED WINDOW, YOU WILL LOSE THIS ABILITY! ***
        • djben
          • Jul 2003
          • 23
          yeah, but it does that after That I have installed it, I didn't even touch the keyboard control option
          • dnewtype
            • May 2003
            • 15
            I have an MS Internet Pro Keyboard that includes a load of extra keys for selecting media tracks, adjusting and muting the sound volume etc - but these don't work with DAP (they do with WinAmp!) Can these be enabled?? (I find them pretty useful) Anyone managed to get them to work?? See the following MS blurb...
              • 43928
              Marked it as a bug now, will look into it.
