Year data missing after conversion
  • gremlin
    • May 2010
    When converting FLAC to MP3, I noticed that the year will not appear in the MP3 files if it's in the following format in the FLAC file:
    YYYY MM
    That is, the YEAR field is completely missing.
    If the format is YYYY or YYYY MM DD in the FLAC file, the year DOES appear in the converted MP3 files as:
    YYYY or
    YYYY-MM-DD
    I seem to recall that the YYYY MM format did carry over previously. Perhaps there's a setting I need to do this, but I can't find it.
    • 43929
    Re: Year data missing after conversion
    You need R14.4 in the beta section of this forum.
