Nit: grayed input fields look like read-only fields
  • l_d_allan
    • Aug 2003
    A minor suggestion for your web-site: You routinely use input fields with light-gray background. These appear to be read-only, since I believe that is the convention to visually indicate a field is read-only.
    It appears you use these differing backgrounds to create visual bands, which makes sense, but the input field itself should perhaps have a white background.
    HTH,
    Lynn Allan
