Asset UPnP R4.1
This topic is closed.
  • Freddiekaberman
    • Aug 2012
    Re: Asset UPnP R4.1
    Hello Spoon,
    Just being a little slow here, I have downloaded the beta from your link above to my PC, but have no idea how to install it on WHS 2011 via remote desktop - with the registered version there was a wizard but with the beta it just wants to install to my PC. Any help appreciated!
      • 43930
      Re: Asset UPnP R4.1
      You remote desktop connect to the WHS machine, then download and run from the WHS machine directly.
      • Freddiekaberman
        • Aug 2012
        Re: Asset UPnP R4.1
        Hello Spoon,
        Installed 4.1 successfully and pleased to say that almost all upstream art is working (AC/DC won't have it for some reason - I can live with that).
        However I still get the same problem with "The_Artists" all being sorted under T, in spite of any changes I make to the options within Asset. Checked again with multiple control points, rescans etc. Do you think there could be a bug here?? If I could fix this, I would be a very happy Asset user, the dynamic browsing seems to work very well indeed..
          • 43930
          Re: Asset UPnP R4.1
          Asset can only recognize "The Artists" not "The_Artists" which is quite unique to your tags
          • JFP
            • Jan 2009
            • 13
            Re: Asset UPnP R4.1
            Hello, about the latest beta version of Asset UPnp R4.1, you state "Removed folder.jpg change detection".
            Does that mean that I can say bye bye to my 18.000+ folder.jpg files ?
            And there will be no way to update these files anymore ?
            I just bought an Ipad and I need bigger artwork (500x500)...
              • 43930
              #21
              Re: Asset UPnP R4.1
              This used to trigger a rescan on a change of folder.jpg, if you update your self you can trigger a manual scan (refresh all) to input the new art, also the embedded art takes preference over folder.jpg
              • Freddiekaberman
                • Aug 2012
                Re: Asset UPnP R4.1
                Hello Spoon,
                Further issues apparent with R4.1 installed on WHS 2011. Initially I identified problems with "The artists" (sorry I was not clear with my earlier posts on this - my albums are ripped with CD Ripper and both Artist and Album Artist are tagged e.g. Eagles, The, but ALWAYS coming up under T, regardless of any options I choose in Asset (I want smart handling to work).
                Now I have played with the options for Artist sort handling, and get the same effect - eg. Billy Joel will come up under B but not J. This happens even when I specify it to display in both sort and non-sort locations.
                I have now managed to get other changes through by fully restarting WHS - e.g. customise the browse tree with a new container, group A-Z listings as ABC...DEF..
                Beginning to wonder if this could be a WHS 2011 issue or I am missing something fundamental.
                Any ideas on this?
                  • 43930
                  #23
                  Re: Asset UPnP R4.1
                  Billy Joel would only appear under 'J' if you have a Artist Sort tag set to Joel, Billy
                  • Freddiekaberman
                    • Aug 2012
                    Re: Asset UPnP R4.1
                    Hello Spoon,
                    Further to my issues of not getting option changes through to my streamers, after changing any options, Asset asks for permission to restart - I check OK but in my case this is not working - and I don't think a re-scan is enough. I finally realised that I needed to restart Asset manually - and it can sometimes need a couple of attempts before my WHS server actually does this, so I guess it could be a server issue. Now everything seems to be working very nicely, but for one small niggle remaining:
                    "The Artists", all tagged Eg. Eagles, The
                    Smart handling selected.
                    When I search Artist/Album - all artists - "The Artists" only show under T
                    When I search Artist/Album - A-Z - E - I get The Eagles nicely presented, and under - T - I get only e.g. "The Temptations"
                    I would like to see an option to present this smart handled artist info under the "all artists" view
                    Do you think this is all down to my tags, or could the folder structure (set up in CD Ripper) have any influence on this?
                      • 43930
                      #25
                      Re: Asset UPnP R4.1
                      How are you selecting T? in the control point (in which case it is not possible, because the control point is getting all artists then only showing those beginning with T)
                      • Freddiekaberman
                        • Aug 2012
                        Re: Asset UPnP R4.1
                        Using the control point (in this case N-stream) if I go into All Artists then A-Z and search under T within Asset - all is fine. What I was looking for is a way to present All Artists and be able to directly scroll through them without using the A-Z search (or indeed the separate a-z search facility within N-stream - I do understand that will only act as a scroll-to function). If I cannot do that because of the control point - no great disaster for me. However it looks strange to me that smart handling of "The Artists" works well within the A-Z search but not in the All Artists View.
                          • 43930
                          #27
                          Re: Asset UPnP R4.1
                          Try 'Asset Control' in the beta section of this forum, it would show correctly for [all artists] (the N Stream must be alphabetic sorting after getting the listing).
                          • DaFork
                            • Jan 2011
                            • 67
                            #28
                            Re: Asset UPnP R4.1
                            May we expect 4.1 final any time soon?
                              • 43930
                              #29
                              Re: Asset UPnP R4.1
                              It is a matter of weeks away.
                                • 43930
                                #30
                                Re: Asset UPnP R4.1
                                Final Update
                                Search update, if get a image or video request it is ignored
                                bug fix: for any search request it does not add any helpers to the title (which might be later used to open an album for example)
