Recording problem
  • richinaz
    • Jan 2012
    Recording problem
    Every time I record a CD, the first song does not record in "Accurate" mode. The song identification letters turn red. The balance of the songs record fine in the Accurate mode. The only solution I have found is to uncheck all the boxes on the far left column except the first song that did not record in Accurate, and then rip again. It requires me to select "Overwrite" on the pop up window.
    Does anyone know how to fix this so that it records the first song properly in the first place?
    • 43930
    Re: Recording problem
    CD Ripper >> Options >> Spin up time, set to 8 seconds
    • richinaz
      • Jan 2012
      Works like a charm. Thank you!!!
      Since you seem to know everything there is to know about this software (judging by this result and the number of your posts), would you recommend Burst or Secure under options?
        • 43930
        Follow this guide:
