dbpoweramp cache does not seem to work
  • Sossity
    • Jan 2010
    • 162
    I needed to re rip a couple of albums, & when I reinserted the discs, the metadata/info I had typed in the meta section in the flac encoder was not there, I had to retype the info again.
    when I tried this on a a different computer, the dbpoweramp cache works on it, but not on my computer. I am currently running dbpower amp under virtulization software, paralells desktop on a mac.
    would this have any affect on the cache?
    I would like the cache to work, so if or when i find I might have to re re rip a cd, dbpoweramp will remember it, so I dont have to type in anything again.
    • 43930
    Re: dbpoweramp cache does not seem to work
    An obvious question, it is checked under the meta drop menu?
    If you put a disc in, then remove, then put back in the info tip should say it is from dBpoweramp Cache, is it?
    • Sossity
      • Jan 2010
      • 162
      yes dbpoweramp cache is checked off in the menu,
      yes it does say from the cache, but the actual info I see is not the same info I typed, but the info from online sources, it starts over again, as though the disc has never been inserted before.
