Primera BravoPro Xi2 Unable to Locate Robot
  • Paul H
    • Aug 2012
    Re: Primera BravoPro Xi2 Unable to Locate Robot
    yes, it is connect through usb.
    • dbfan
      • Jan 2011
      • 937
      There is another drive letter other than h?
      • Paul H
        • Aug 2012
        Yes the drives are G and H
        • dbfan
          • Jan 2011
          • 937
          I take it if you try to configure g it does not work either.
          • Paul H
            • Aug 2012
            correct. Both are configured to primera setting. Both drives will rip if I manual load and unload. The primera duplication software can control the robots.
              • 43928
              #21
              Post the test load debug log please.
              • Paul H
                • Aug 2012
                Unable to locate Primera robot containing drive 'G', please check connection.
                Beginning Test
                Running Program: "C:\Program Files\Illustrate\dBpoweramp\BatchRipper\Loaders\Pr imera\Load\Load.exe" --stoponmultidiscsloaded="yes" --drive="G" --logfile="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\dBBBA9 D.tmp" --passerrorsback="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \dBBBA9E.tmp"
                Running...
                Primera Looking For Drive:G
                Primera PTRobot_Initialize: EnumRobots: EnumDrives Robot *0: *** Error: Unable to locate Primera robot containing drive 'G', please check connection.
                PTRobot_Destroy: Destroyed
                Testing Complete
                  • 43928
                  #23
                  Try using Computer Management >> Storage
                  and set the G drive to a higher letter, such as I then try again.
                  • Paul H
                    • Aug 2012
                    Same issue with drives set to higher letters.
                    Beginning Test
                    Running Program: "C:\Program Files\Illustrate\dBpoweramp\BatchRipper\Loaders\Pr imera\Load\Load.exe" --stoponmultidiscsloaded="yes" --drive="I" --logfile="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\dBB247 .tmp" --passerrorsback="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \dBB248.tmp"
                    Running...
                    Primera Looking For Drive:I
                    Primera PTRobot_Initialize: EnumRobots: EnumDrives Robot *0: *** Error: Unable to locate Primera robot containing drive 'I', please check connection.
                    Testing Complete
