Help With MT Fuison
  • Beka
    • Aug 2010
    Help With MT Fuison
    Somebody can help me with MT-Fusion.
    robot doesnt worked.
    • 43930
    Re: Help With MT Fuison
    The robot works with other programs?
    • Beka
      • Aug 2010
      Robot works with DBPoweramp batch ripper but the robot does not work. Where can i find driver for Media Technics Fusion.
      • Beka
        • Aug 2010
        The problem isnt solved with Dbpoweramp batch ripper because the robot doesnt work. The correct drive is already installed bud still it doesnt work. Do you know any solution please send it to my e-mail address: behsadk@hotmail.com Greetz Beka:smile2:
          • 43930
          We do not supply drivers for the MT Fusion, you have acquired MT Fusion drivers for the Batch Ripper?
          • Beka
            • Aug 2010
            after i installed batch ripper (newest version). In the configuration from batch ripper i saw mt fusion drivers.
              • 43930
              The newest batch ripper would not have installed them, it only comes with the drivers for 'Manual Load & Auto Eject'. If you have configured the Fusion, look in the configuration program, you might have to change the com port, or even bit rate. Test the load in the configuration program.
              • Beka
                • Aug 2010
                This is configuration batch ripper.
                • Beka
                  • Aug 2010
                  • sonyman
                    • May 2008
                    • 83
                    Hello ,
                    - install the Amtren Driver
                    - set the COM Speed from 9600 to 38400 Baud
                    - thats all
                    Have Fun!:smile2:
