First Post Question: Rip to mono wav file
  • Audiobooker
    • Aug 2010
    Hi everyone
    Just signed up to the forum, as this sounds like just what we need.
    A couple of questions before our company invests in the program, hope some of you out there can clarify its capabilities.
    We need to rip to a mono summed wav file from audio CD, is this possible.
    Also, can MP3CDs be recognised and converted to mono summed wav. ( I know this is not going to gain any quality, its just our work flow proceedure here.)
    Any feedback greatly appreciated.
    Cheers
    Ben
    • 43936
    Re: First Post Question: Rip to mono wav file
    Add the DSP effect 'Channel Count'
    • Audiobooker
      • Aug 2010
      Thats good to know, thanks.
      Is there a limitation on what disc formats will be recognised to perform the rips?
        • 43936
        For data CDs (ie a disk with mp3s), browse to the disc, select all the files, right click on one >> Convert To
        • Audiobooker
          • Aug 2010
          Can that easily be setup to run automatically on the Robot Loaders like the Primeras?
            • 43936
            Data CDs cannot be automated.
            • Audiobooker
              • Aug 2010
              Is ripping dependent on the audio cds info being available on CDDB, some other programs need this to make ripping possible.
              I ask because Audiobooks very often are not on such databases.
              Cheers
                • 43936
                Metadata is required for batch ripping yes.
                • Audiobooker
                  • Aug 2010
                  Thank you. It looks like we can set it to read CD text, which may help, but I wonder if it will rip if the CD doesn't have a title.
                  On another topic, does Batch Ripper work with the Rimage Producer series of machines? How about Datatronics Minicubis?
                  Thanks again
                    • 43936
                    Minicubis yes, RImage I do not think so. If there is no metadata the cd is rejected, you can then rip it manually.
