DSP Effects R7 Beta
This topic is closed.
  • 3527aeg
    • Jun 2010
    Re: DSP Effects R7 Beta
    you should see the file end up with a tag of:
    Artist the now Very Long
    Does this happen?
    Yes, it looks looks that.
    What I would like is: Artist The Now Very Long
    dBpoweramp used to do all tags this way, and this the the naming convention I prefer. Is there another setting that controls this which may have been changed when I installed the beta?
      • 43930
      Try the option 'Lowercase except first Letter'
      • twit
        • Jul 2010
        • 79
        If I run my albums through Replaygain after ripping, does the +6 db option really get me anything other than different Replaygain values? To put it another way, shouldn't a song play just as loud with Replaygain applied (assuming Replaygain run after ripping), regardless of the +6 db setting? If there is a difference in playback volume or fidelity with a song with Replaygain and the +6db option applied and not applied, could you please describe? Thanks very much.
          • 43930
          If you are using replaygain then the +6db makes no difference as it is corrected by replaygain.
            • 43930
            Update 12th November
            Bug Fix: Write Metadata DSP Effect would give errors if the source was a CD disc
            • Barough
              • Apr 2005
              • 54
              #21
              Is it more things that will be fixed/added into R7 before it will be officially released?
              • EliC
                • 1175
                #22
                Re: Write Metadata DSP. I admit, I have not actually played with it. But this will write the final meta-data to a file correct? So if PerfectMeta is used it writes the perfectmeta to a html or xml file. Any chance you would modify this allow for writing of source meta-data? Would be nice to be able to preserve the original source meta-data from AMG, GD3, MB and freedb.
                  • 43930
                  #23
                  Now released.
                  EliC - The other metadata does not make it outside of CD Ripper.
