Asset Control Discussions
  • StaryKaszub
    • Mar 2011
    Re: Asset Control Discussions
    I use the following setup:
    • Windows Home Server with Asset UPnP
    • uPlayer
    • Asset Control
    • WD TV Live
    Asset Control has not problem finiding and communication with Asset UPnP. Asset Control finds WD TV Live, but I was unable to play anything on this device. Is this expected?
    When I run on the same laptop (Windows 7) both uPlayer and Asset Control then I can play music served by Asset UPnP running on the Windows Home Server.
    With Asset Control I have couple useability issues, so any advice/explanation will be higly appreciated:
    1. Selecting in the Library [Asset UPnP]->[Playlists]->[Jukebox Track Selection] - gives me the list of selected tracks. Click on Play button - nothing happens (no track is played) - why? Why do I have to click 100 times (this is the default jukebox playlist length in Asset UPnP) on tracks in the libary pane to move them to the playlist pane?
    2. Once I get my tracks on the playlist I can change the order in which they are played. Why changing the playing order clears the playlist?
      • 43930
      WD Live has many issues with Asset Control, they will be looked at when development work resumes.
      • talisker
        • Jan 2010
        • 14
        Hi Spoon, There's not much happened on Asset Control within the last weeks/months. I'm wondering how your release-schedule looks like. Linn has developed a new major release Davaar which is in beta now. Will you update Asset Control soon to be compatible with Davaar? Thanks for an update.
          • 43930
          Yes
          • petacat
            • Sep 2010
            • 11
            Hello Spoon. I am not seeing my Oppo95 on Asset Control. Is that something that will be looked at when work starts again?
              • 43930
              Do you see it with other control points?
              • ctn
                • Mar 2011
                Why is it that when I select an album and then press "Play Album" (and the list of songs are transferred to the playlist) it only plays the songs for a few seconds and then skip to the next one on the list. What am I doing wrong?
                I'm using Asset Control with a RipNas.
                  • 43930
                  It means that Asset Control is not able to detect the player is actually playing the track.
                  • talisker
                    • Jan 2010
                    • 14
                    Hi Spoon, just to get an idea, by when have you planed to implement the Linn Davaar compatibility into Asset Control. Is there any further developement planed on this product? Thanks for an update on this.
                      • 43930
                      I cannot commit to a time scale, all I can say at this time is Illustrate are working behind the scenes on something big and hope to announce in about 4 weeks.
                      • cgospsa
                        • Jan 2011
                        Hello from Spain...
                        All you make is Big!!! ThankĀ“s Mr. Spoon.
                        I can control the Linn DS Davaar if no select the gapless DS.
                        Await for a big Asset Control... Uhmmm...
                        Cheers.
                        • talisker
                          • Jan 2010
                          • 14
                          Hi Spoon, thanks for your quick reply. It sounds very promising ! I'm very intent to see what you have done then. :smile2:
                          • petacat
                            • Sep 2010
                            • 11
                            I found a couple of other control points and they cannot see tyhe Oppo 95 either ... seems not to be a renderer.
                            • Chip
                              • Aug 2008
                              • 96
                              Re: Asset Control Discussions - Davaar Compatibility
                              Hi Spoon,
                              Does Asset UPnP Version 3 Premium and Asset Control October 2010 Beta work with Linn Davaar?
                              If not, can you say anything about when it will be compatible?
                              Chip
                                • 43930
                                The server is always going to be compatible with any future release, Asset Control would need updating.
