FLAC default settings
  • texasflood
    • Jul 2008
    • 58
    When ripping to flac, unlike to mp3, it doesn't give the option to change to stereo, mono or joint stereo. My question is, does the ripper rip the cd as source, or will it try to rip a mono disc as stereo?
    • 43926
    Re: FLAC default settings
    Every CD is stereo, even the mono CDs (in that there are 2 channels, just identical).
    Internally FLAC will have automatic Joint Stereo / Cross-side routines.
    • texasflood
      • Jul 2008
      • 58
      Thanks for the quick reply. Okay, that answers that question. Now, when converting to mp3 using the music converter, I have been using joint stereo for cds that contain stereo and mono recordings or only mono recordings. Is there any problem with that, or should I use "as source"? Personally, I can't hear a bit of difference between stereo and joint stereo. Do my ears deceive me?
        • 43926
        Use [as source] where presented.
        • texasflood
          • Jul 2008
          • 58
          thanks, just wanted to be clear so i didn't make any mistakes and have to start all over
