Album and track info missing...
  • howard passman
    • Jan 2010
    I'm brand new to the DBP thing. I have downlaoded the trial version of Reference and downloaded the CD Writer also.
    I tried burning a CD using files converted from the Beatles Remastered FLAC files on the USB set. First I converted to .wac and then .aac. When I burned the CD neither shows track info.
    What am I not doing?
    Howard
    • 43929
    Re: Album and track info missing...
    Not showing meta data? on a standard audio cd?
    • Wayne
      • Aug 2002
      • 1252
      Do the original flac files contain album and track info?
      Are you refering to CD Text on the resultant audio CD? The CD Writer doesn't support this.
      • Arnold_Layne
        • Nov 2009
        • 38
        OP is refering to the limited edition FLAC files that come on an apple shaped USB flash drive.
        A_l
          • 43929
          and he burnt them to CD and asked why there is no meta data associated with that CD, he has created a new CD which is not in any of the online metadata databases.
