CD is not ripping & encoding
    • 43928
    Re: CD is not ripping & encoding
    FUA is for Plextor drives only, you have a Plextor drive?
    • arvind somany
      • Jul 2009
      • 31
      No I do not have a Plextor drive, so I guess I cannot use FUA. How can I use Ultra Secure ripping & C2 Pointer?
      Arvind
        • 43928
        Yes c2 and Ultra should give no problems.
        • arvind somany
          • Jul 2009
          • 31
          But I am unable to encode using Secure Rip with Ultra Secure Ripping & C2 pointer checked or unchecked. In both case FUA is unchecked. Even with Test conversion it does not rip.
          With "Burst" it is ripping & encoding.
          Arvind
          • arvind somany
            • Jul 2009
            • 31
            Let me update to the present status:
            Laptop with Vista o/s:
            No ripping & encoding with "Burst" or "Secure" even on Test Conversion.
            Laptop with Windows XP o/s:
            Ripping & Encoding using "Burst".
            Not ripping or encoding using "Secure", even on test conversion. FUA is unchecked.
            Arvind
              • 43928
              #21
              On the Vista Machine try >> Options >> Communication >> Windows Built In (as a test)
              • arvind somany
                • Jul 2009
                • 31
                #22
                Some good news at last; I reconfigured Vista & now it is ripping & encoding with Secure Rip but with C2 pointer unchecked. Though the drive supports C2 pointer. Can you help me with this?
                Secondly I am unable to activate AMG even though I am entering the order number.
                  • 43928
                  #23
                  What did you do to get secure ripping working?
                  Email your AMG order number please:
                  • arvind somany
                    • Jul 2009
                    • 31
                    #24
                    I sent the laptop to the company & they reinstalled Vista & it started secure ripping with C2 pointer unchecked.
                    E mailing you the order number.
                    • arvind somany
                      • Jul 2009
                      • 31
                      #25
                      I did'nt get a reply, why C2 Pointer has to remain unchecked.
                        • 43928
                        #26
                        What happens now if c2 is checked?
                        • arvind somany
                          • Jul 2009
                          • 31
                          #27
                          If the C2 is checked encoding stops.
                            • 43928
                            #28
                            Are you 100% sure your drive supports C2?
                            • arvind somany
                              • Jul 2009
                              • 31
                              #29
                              Yes, it says in the tech details of the drive & I also conducted the test with a merked CD & it showed detection.
                              • arvind somany
                                • Jul 2009
                                • 31
                                #30
                                I havent recd a reply to the problem of C2 as yet.
