Plextor CD Drive Tray Controlling Problem
  • sonyman
    • May 2008
    • 83
    I Have found a Problem with using the Batchripper and Plextor CD Drives.
    When i using a Plextor CD Drive with the Batchripper i have following Error:
    ->You Start the Batchripper
    ->The tray from the Plextor Drive opens and after 2min can you see the Error message on the Screen
    Tray Problem:
    The Tray for Drive E, did not open, press OK when this has been remedied by Hand
    I have testet with following Drives:
    1. Plextor Plexwriter Premium
    2. Plextor PX-W5224TA
    3. Plextor PX-W4824TA
    4. Plextor PX-W2410TA
    (All Plextorś have the same effect!)
    I have testet with different PCś and different Amtren Roboticś
    After replace the Plextor Device with a other (Samsung Yamaha LG) works the Batchripper Fine!!
    • 43930
    Re: Plextor CD Drive Tray Controlling Problem
    Drives 2-4 would possibly not work, due to them not being MMC compliant, the Premium should work, how is it connected to the PC, which windows are you running?
    • sonyman
      • May 2008
      • 83
      Tryed OS:
      Win XP SP2
      Win XP SP3
      Connection via USB
      Tryed Chipset:
      1. Ali M5624
      2. Genesys Logic GL811E
      How can i solve the Problem?
        • 43930
        Try a direct IDE connection if you can.
        • sonyman
          • May 2008
          • 83
          Dear Spoon,
          i think this is no USB to IDE Bridge Problem!
          I have testet the Plextor PX-W5224TA CD Burner USB connected with the dbpoweramp CD-Ripper.
          With the Program EJET Button i can Open and Close the CD Tray!
          The Plextor CD Burner only dosent Work with the Batchripper!
          Best Regards
          Bastian
            • 43930
            Do you have to select the special 'D8' read mode in CD Ripper?
            • sonyman
              • May 2008
              • 83
              No
              All settings are standard settings.
              No change!
              Bastian
              • bhoar
                • Sep 2006
                • 1173
                Originally posted by sonyman
                No
                No change!
                Bastian - that error message is from my driver. Add --olderdrives to each of the five command lines in the batch ripper setup for your robot.
                Spoon - sorry I didn't catch this sooner.
                -brendan
                • sonyman
                  • May 2008
                  • 83
                  Thanks Brendan!
                  The "old" Plextor CD-Recorder are good Ripping Devices !
                  Bastian
                  • bhoar
                    • Sep 2006
                    • 1173
                    Thanks Brendan!
                    Bastian,
                    Let us know if the --olderdrives flag resolves the issue for you.
                    -brendan
                    • sonyman
                      • May 2008
                      • 83
                      Dear Brendan,
                      i have now tested the new Configuration.
                      This is each one of the five changed command lines
                      --olderdrives --comport=COM6 --comspeed=9600
                      2nd Running
                      --comport=COM6 --comspeed=9600 --olderdrives
                      Is this right?
                      The Problem is not fixed!
                      Bastian
                      • bhoar
                        • Sep 2006
                        • 1173
                        Dear Brendan,
                        This is each one of the five changed command lines: --olderdrives --comport=COM6 --comspeed=9600
                        2nd Running: --comport=COM6 --comspeed=9600 --olderdrives
                        Is this right?
                        Bastian:
                        Try --olddrives instead of --olderdrives. The current code accepts both, but older versions might only accept the first one.
                        If that doesn't work, I might need to send you an update to work with partially-compliant MMC drives.
                        Which robot do you have this in?
                        -brendan
                        • sonyman
                          • May 2008
                          • 83
                          IT Works!
                          Thanks!
                          Bastian
