Show Ripper doesn't Work
  • k1_
    • Mar 2009
    • 23
    If I try the option Show Ripper in Batch Ripper to bring upp the Ripper to check disks that are having re-reads, nothing happens.
    The machine is a Vista x64 system, clean only used with dbPowerAmp, no other software, with all updates installed. 8 core CPU with 4Gb RAM.
    Using dbPowerAmp 13.2 (beta) and BatchRipper 1.2 (beta).
    Any clue what the problem are?
    /Keivan
    • 43930
    Re: Show Ripper doesn't Work
    Minimise Batch Ripper, often the window is not picked up by windows.
    • k1_
      • Mar 2009
      • 23
      Yes, that works fine..
