grabber + fade = probleme
  • pierrep
    • Oct 2008
    • 11
    hello,
    I've a problem with fadeout with dsp combinaison
    i read this thread
    and i try to use the DSP effect "non live".
    I use DBpowerAmp 13.1
    DSP R3
    my command line is :
    Code:
    CoreConverter.exe -infile="c:\test_full.wma" -outfile="c:\test_30sec_from_full.mp3"
    -convert_to="mp3 (Lame)" -b 64 -encoding="FAST" -dspeffect1="Grabber=-lengthms={qt}30000{qt} -position={qt}10000{qt}"
    -dspeffect2="Fade=-inlengthms={qt}4000{qt} -outlengthms={qt}4000{qt}"
    -dspeffect3="Force Non-Live="
    -noidtag
    but i have no fade out. (but i have fade in)
    Can you fix that ?
    thanks a lot for DBPowerAmp !
    • 43928
    Re: grabber + fade = probleme
    If you use Music Converter to do the conversion with those settings, is the fade out done?
    • pierrep
      • Oct 2008
      • 11
      yes fade out is done when i use those settings in Music Converter.
      another test ?
      thanks for you support.
      [edit]
      in addition, i think start position in grabber with coreconverter (+fade +force non live) always start at 0sec.
      all is ok with music converter.
      [/edit]
      • pierrep
        • Oct 2008
        • 11
        ok i found the problem.
        I use virtual machine and send this command over ssh.
        Code:
        ssh  user@localhost -p 2222 'CoreConverter.exe
        -infile="z:\\\\tmp\\test_full.wma"
        -outfile="z:\\\\tmp\\test_30sec_from_full.mp3"
        -convert_to="mp3_(Lame)" -b 64 -encoding="FAST"
        -dspeffect3="Force Non-Live="'
        there are errors when there are spaces between the quotation marks.
        It's real problem.
        I have already report this problem between linux and windows. I never find any solution except rename plugin like "mp3_(Lame)"
        Sorry Spoon for this.
        Contact me if you want more information or tests on virtual machine.
