Can't get Accurate rip offset for PX-B900A
  • pls1
    • Jan 2008
    • 91
    I've tried six different disc, all of which have set the offset in other drives. The CDR site actually gave this drive high marks for DEA.
    I keep getting the error that the offset is wrong and to try another disc.
    any ideas?
    Phil
    • 43930
    Re: Can't get Accurate rip offset for PX-B900A
    Have a look at the log file, in %appdata%\acuraterip
    • pls1
      • Jan 2008
      • 91
      what location is this? i searched for the string and can't find the log in the app data folder. On the meta-data tag for accuraterip shows 015-00270f80-01ba6317-ce10f20f-1.
      could you be more specific?
        • 43930
        select start >> Run, type:
        %appdata%\accuraterip\
        the file is AccurateRip-Offset-log.txt
        • pls1
          • Jan 2008
          • 91
          OK when I ran the string I ended up in the folder where I was before.
          All I see are .BIN files and no text files. I searched the hard disc for "Offset-log.txt" as well as any .txt file with "offset" in the title and turned up nothing. There is no problem with the other three models of drive in this machine..., all will " accuraterip" CDs in the accuraterip database
          There is such a .txt file on my other machine but that text file only shows the PX-230 and not the other three models of drive which have been properly accurate rip configured
          Phil
          • pls1
            • Jan 2008
            • 91
            I installed another model drive in the machine and did the accurate rip calibration. No problem on that drive and now there is a log. Still can't get a calibration on the B900 using the same calibration disc and the B900 works as a drive.
            Phil
            • pls1
              • Jan 2008
              • 91
              Got-it... rip offset for PX-B900A
              De install and reinstall drive. Now it gives me the offset even though every other drive function worked before (and after).
              Phil
                • 43930
                Keep trying different key discs on the off chance.
                • pls1
                  • Jan 2008
                  • 91
                  sorry my post was cryptic. After the deinstall/reistall I got 3 of the key discs to work. What's weird is there was no problem with this drives operation. But it is now working with accuraterip. Strange.
                  phil
                    • 43930
                    If the drive is not in AR database you need 3 matching cds.
