Can't get Accurate rip offset for PX-B900A
  • pls1
    • Jan 2008
    • 91
    I've tried six different disc, all of which have set the offset in other drives. The CDR site actually gave this drive high marks for DEA.
    I keep getting the error that the offset is wrong and to try another disc.
    any ideas?
    Phil
    Re: Can't get Accurate rip offset for PX-B900A
    Have a look at the log file, in %appdata%\acuraterip
    • pls1
      • Jan 2008
      • 91
      what location is this? i searched for the string and can't find the log in the app data folder. On the meta-data tag for accuraterip shows 015-00270f80-01ba6317-ce10f20f-1.
      could you be more specific?
        select start >> Run, type:
        %appdata%\accuraterip\
        the file is AccurateRip-Offset-log.txt
        • pls1
          • Jan 2008
          • 91
          OK when I ran the string I ended up in the folder where I was before.
          All I see are .BIN files and no text files. I searched the hard disc for "Offset-log.txt" as well as any .txt file with "offset" in the title and turned up nothing. There is no problem with the other three models of drive in this machine..., all will " accuraterip" CDs in the accuraterip database
          There is such a .txt file on my other machine but that text file only shows the PX-230 and not the other three models of drive which have been properly accurate rip configured
          Phil
          • pls1
            • Jan 2008
            • 91
            I installed another model drive in the machine and did the accurate rip calibration. No problem on that drive and now there is a log. Still can't get a calibration on the B900 using the same calibration disc and the B900 works as a drive.
            Phil
            • pls1
              • Jan 2008
              • 91
              Got-it... rip offset for PX-B900A
              De install and reinstall drive. Now it gives me the offset even though every other drive function worked before (and after).
              Phil
                Keep trying different key discs on the off chance.
                • pls1
                  • Jan 2008
                  • 91
                  sorry my post was cryptic. After the deinstall/reistall I got 3 of the key discs to work. What's weird is there was no problem with this drives operation. But it is now working with accuraterip. Strange.
                  phil
                    If the drive is not in AR database you need 3 matching cds.
