Rip to Ram problem.
  • xhail
    Rip to Ram problem.
    Excellent program! I am really impressed. I do have one problem though. Rip to Ram is definitely not faster on my machine, it's slower. I have located any minimum requirements on the site, so thought I'd ask about it here. I realize it could very well be my old computer is the problem. I tried it by setting the Ram to Use to 128, and auto, seemed to make no difference. I had 230 megs free, I was monitoring it, and no more than 80 megs was ever used, by the convertion.
    XP Pro sp1
    Dell Optiplex GX1
    PII 450
    384 megs of ram
    Samsung CDR 8.8.32
    IF it's a case of my CDR being too old, that's easily rectified. Or maybe I just need to tweak something?
    Thanx .
    • 43930
    80 sounds about right, it will only allocate the maximum 1 track requires.
    Did you have the 'Encode at Same Time' option on as well?
    To do speed trials, try going to wave files as a test, what 'x ripping speed' were you getting?
    • xhail
      Yes, using Rip and Encode At The Same Time
      Ripping speed is 12 to 13x, wav or mp3.
        • 43930
        Please rip to a wave file (quite a large track) with Rip to Ram on and off and post the times.
        • xhail
          with rip to ram
          wave = 26 secs
          without
          wave = 32 secs
          with
          MP3 = 2:30
          without
          Mp3 = 2:37
          I see I was wrong, it is faster, but not much..........
            • 43930
            That is almost a 20% speed increase (on the wave anyhow).
            Even if you got a cd drive that could rip at x24 you can knock about 14 seconds off the mp3 or wave time, so no huge speed increase.
            • xhail
              Ok.... no big deal really, it's just that on the Power pack page it states
              Lightening Fast CD Ripping with 'Rip to Ram' and 'Rip & Encode at Same Time' options,
              I expected more, but it's not a problem, I love this software! :D
                • 43930
                That is just advertising speak
                "Cleans whiter than white"
