How to rip thousands of cds?
  • bhoar
    • Sep 2006
    • 1173
    Re: How to rip thousands of cds?
    Originally posted by LtData
    I mean that if you have multiple CD drives and just call CD ripper multiple times, you end up slowing down the whole process to the point of probably eliminating your advantage of using 2 CD drives. Use the Batch Ripper instead.
    LtData - I suspect this isn't the case, at least, not in a major way. The batch ripper itself does this, launching multiple cdgrab.exe processes, hidden from view, one per drive.
    Manually running the cdgrab.exe's is almost the same but with less automation. You just have to watch to make sure that each cdgrab doesn't start looking at a different (wrong) drive on CD insert/eject, as they are wont to do. Or rather, when one does this, you must manually switching the drive letter back...and you will end up doing this a lot.
    If you don't catch it, this can lead to two cdgrab.exe's trying to rip from the same CD drive at the same drive...if you aren't careful before you click the Rip button. That certainly would decrease throughput...
    The batch ripper avoids this as it technically runs one cdgrab.exe per *CD*, each one told to exit after a CD finishes ripping, so it doesn't wait around, dejected, cd-less, looking for another CD friend to play with. Also, when the cdgrab.exe launched, the drive is already loaded with a spun up CD and the passed parameters force the cdgrab.exe to look at a specific drive. So, with the batch ripper, there's no chance of the cdgrab.exe getting distracted by other drives.
    -brendan
    • NoMo
      • Aug 2008
      • 13
      K, you scared me for a sec
      NoMo
      • Mikeraphone
        • Aug 2010
        >>same post form Hydrogen Audio<<
        Entry level into robotic (non carrousel) loading is the Datatronics MiniCubis (they are the manufactuer, the drives also are sold under the names: MFDigital Baxter, Stordigital 25, Diskmakers Pico, Acronova DupliQ).
        They have a 25 disc capacity, which is about 1 hours of ripping. Currently only 1 of these drives can be used on the same PC at once, we (dBpoweramp) are working with datatronics to get multiple drives working from the same PC.
        Can multiple MiniCubises run at the same time now on one PC? It's been three years since this post, I hope some progress has been made
          • 43930
          No they cannot
