CD Writer does not now work
  • Randisc
    • Aug 2007
    I get dBpoweramp Music Converter pop up window stating
    Unknown Command Line: '<UseLastSettings> <SkipFinished>
    the only option is OK
    I have uninstalled and reinstalled several times.
    Please help anyone
    • 43926
    Re: CD Writer does not now work
    You have installed R12 of music converter which is incompatible with the older CD Writer. Your best bet is to install the latest beta version of CD writer (from the beta section of this forum).
    • blabgoo
      • May 2008
      I have the same problem. I have had most of the products but decided to try the cd writer and I cannot get it to work. (same errors as above)
      I tried what you suggested and now I get - CD Writer Requires Music Converter R13 Reference or newer. However, I cannot find that anyplace.
      ARG.
        • 43926
        See:
        If you have a Power Pack or Reference license, install this over the top without uninstalling and will remain registered. This alpha will cease to function after 08 2008 (will be in full release by then). Download: &lt;now released&gt; CD Ripper: PerfectMeta data added - uses commercial AMG and GD3 as well as MusicBrainz
