track offset
  • hiperpinguino
    • May 2002
    • 46
    track offset
    Here's a little problem that I've mentioned in the past, but it's become really bothersome recently, so I thought I'd bring it up again.
    Up until a few beta releases ago, DMC Audio CD Input worked fine on my computer. Now, however, tracks start and end at somewhat skewed places- the start of one track will be stuck in at the end of the previous one, and so on. I've tried messing with the track offset function, but it seems that no matter what offset I choose, a few tracks still get screwed up.
    Now that DAP can play Audio CDs, the problem has transferred over to it as well- tracks end with the beginning of the next track, and each subsequent track is likewise cut off in the beginning.
    I'm assuming that this is some kind of bug that got stuck in a recent beta (it's only been happening for about a month or so), but I'm not sure. Thanks for whatever help you might be able to provide. :smile2:
    • 43930
    After you have set the track offset to 0 and ripp, exit Audio CD Input and do Start >> Run:
    regedit.exe
    browse to HKEY_CURRENT_USER\Software\Illustrate\dBpoweramp\C DGrab
    TrackOffset should be 0, is it?
    • hiperpinguino
      • May 2002
      • 46
      Yes, DriveOffset=0.
        • 43930
        Odd, has anyone else seen this?
        • hiperpinguino
          • May 2002
          • 46
          Here's another interesting development- I tried running Audio CD Input with my second cd drive and it works fine. Could be that my drive's just messed up, you never know:supersmil
            • 43930
            Yes it does sound like it is down to the drive, you could try setting a Drive Offset on the Options page.
