dmc r12b4 registration problem
  • flash
    • Dec 2006
    Hello,
    I was using the r12b4 version, I registered the product, payed the license fee and installed the product as instructed. Now the configuration screen says version 11.5 and only 15 days left of trial use.
    I more than likely missed something, but could you help me out with this problem?
    Thank You
    Re: dmc r12b4 registration problem
    The current registered version is dMC r11.5. The r12b4 version is only a trial currently. A registered version will be released when the final version of dMC r12 is released. Until then, do a total uninstall described here: http://forum.dbpoweramp.com/showthread.php?t=6828
    Then install either r12b4 or your registered r11.5.
